Datsunpowers Posted May 23 Share Posted May 23 Darom, wanted to say a big thank you. My PTZ throttle body was making the same whistling noise, and it was driving me crazy. Grinding the sharp edges off tonight reduced the noise to an acceptable level. It's much improved now! I hope I can help you out with your closed loop idle settings. I spent a lot of time working to get my car to idle properly at 750 RPMs with the PTZ throttle body. I had to recenter the throttle plate and close the throttle screw closed more with a little grinding on the stop. I also had to change out the GM IAC motor with a different model. The one that came with the throttle body would not close and seal for me all the way. So, I went to the junk yard and pulled several different GM IAC models. The IAC that is working for me I think it came from a Grandprix V6. Here are my Megasquirt closed loop settings. I hope this helps you out. Thanks, Tom Quote Link to comment Share on other sites More sharing options...
darom Posted May 24 Author Share Posted May 24 Hi @Datsunpowers Tom! I appreciate your time posting your IAC setup here. I wish Protunerz would grind the sharp edges at their factory. I talked to them, they are aware of all this whistling business with their intakes. They are great guys and I got quick tech question responses from them. But the noise is an embarrassment to a pricey car part. I have a few questions for you: - Do you set up your throttle blade to be completely closed and then configure your IAC to provide additional air to get your target 750 rpm? I went over this subject on a msextra forum as well, and it appears there are 2 ways to do it. One is to open the blade a little and IAC completely closed at idle. Another - the throttle blade is physically closed and IAC is providing air for idling target speed. I went with the 1st option, since I couldn't get my IAC to provide predictable behavior. One day it would be idling at 900 rpms, next day - 800-850 rpm, another - around 1000 rpm. I figured the IAC's min steps and step size needed to be played with and per Madcaw's advice, I left it on 'Always On'. This helped somewhat. I also bought another IAC for a 1999 Camaro V8 (Ultra-Power AC162) to test (10$ special from Rockauto), but I haven't installed it yet. I suspect my IAC is not completely sealing the opening, thus these fluctuations. - Open-loop vs closed-loop question I removed my a/c a while back, and I have a 5-speed. I thought the closed-loop idle control is suited for the cars with big electrical loads (like electric fans, a/c compressor kicking in) or an automatic transmission. I have a belt driven fan. All my headlights are converted to using relays. I set up the open-loop since it was the easiest option. Would you recommend for my car to switch to the closed-loop idle control? If you don't mind checking my tune/idle and a driving log, I'd appreciate it. What are your car's specs? Can you share your tune? Thanks! Den 2025-05-18_13.51.43.mlg 2025-05-18-adj-IAC.msq 2025-05-10_11.12.19-driving.mlg Quote Link to comment Share on other sites More sharing options...
Datsunpowers Posted May 25 Share Posted May 25 (edited) Den, I agree with you that the ProtunerZ guys are very helpful, and stand behand their products. I am so glad that the car doesn't whistle anymore. I am no expert here, so take this as advice. Your mileage my vary. 🙂 The car is a 71 240z. I live at 8,000 feet and I see a lot of altitude change to 5,600 feet in CO, so I am running %Baro. Here is the setup on my engine: 3L Turbo Stroker, 88mm JE forged pistons 8.43:1, Max Speed rods, ARP head, rod, main bolts, Electramotive L7 Cam, Garret GTX Gen II 3071 turbo, Water-to-Air Intercooler, ProtunerZ intake, turbo manifold, downpipe, Arizona Z Car 7 QT oil pan. Megasquirt V 3.57 with the expansion daughter board, sequential injection, 280zx Turbo CAS, GM Truck COP, Bosch 440CC injectors with 43 Psi. This is a new engine that has about 2,000 miles on it. Its running very well over the stock turbo engine I had in the car. I did set up the throttle blade to be completely closed and then configured the IAC to provide additional air to get to the target of 750 rpm. This has allowed me to have it start in the cold at -10F and 90F and warm up properly. I do find it likes a AFR of 13.5 for a good smooth idle at 17 degrees of timing at 750RPM. I enclosed my MSQ tune file Looking over your setup I noticed a couple things you should check. I will make the assumption the engine is stock with no cam and stock cam timing. 1. SYNC LOSS: (This is not good. fix this first otherwise you're chasing your tail) Your RPM signal has noise on it and two dropouts where the rpm goes to zero in a four-minute period. You need to confirm your sending a clean signal to the ECU. This is not my area of expertise with a hall sensor and tooth wheel as I am running optical from the 280zx turbo CAS. Check your sensor gap and grounding and shield grounding. Others here have way more experience in this area. 2. The throttle position sensor: You have 464 steps where mine has 679 steps. I would make sure it has full travel and re-calibrate it. I also noticed that your sensors are unlocked. This could be the sensitive throttle you mentioned. 3. Timing: It can't hurt to double check your base timing. I would confirm it at (Fixed Timing setting set to 15 degrees) with a timing light. Make sure you confirm zero TDC with the piston at TDC. I have had a couple harmonic balancers spin on me. I am not sure how the missing tooth crank wheel bolts to the balancer, so I could be incorrect here. 4. TPS WOT Curve: You have it set to start a zero and it keeps firing off your acceleration enrichment at idle. Your AFR is going rich to 10.4 when that happens. Move the starting point rpm so it just starts to fire when you start to accelerate. Take a look at my tune for a starting point. You don't want to fire off acceleration when its idling. 5. MAP sensor: Looking at the one warm up idle log. The timing moves from 19 to 23 degrees with no TPS input. Then is settles down to 14.8 while the MAP remained fairly steady at 41 kPa. You would think this would change with the timing swings, so check your MAP hose to the MAP sensor and the MAP sensor wiring. I see you have a GM-1Bar sensor configured. On my engine I have a vacuum of 27 kPa. It could be normal for your engine but check for vacuum leaks also. Here is a great article from DIY Auto Tune on closed loop ldle. MS3Pro Closed Loop Idle - Stepper Valve - DIYAutoTune.com 6. I would adjust your timing at the lower values. Set it up so you have 500 = 19 and have 17 degrees at 750. this way it will give you a little timing when the electrical load increases to bring the RPM back up. Looking over the idle/accel tab I have more settings available and a 16x16 table to play with. I think this is the limitation on the Microsquirt vs the Megasquirt. Open loop vs. closed loop: I have had a stock 280 NA with factory injection and MSX fuel only to start with just the air bleed screw and bi metal IAC valve and it worked and idled fine. When I swapped to a stock turbo 280ZX engine with factory injection. I changed the IAC valve to a Ford 2 wire valve and used open loop then closed loop as I learned the system features. Both worked well but I could get more fuel control with closed loop. You have a lot more temperature swings and intake temps with a turbo engine under the hood that effects idle control. Now with the current stroker turbo engine and the PTZ 75mm throttle body. I spent a lot of time getting the GM 4 wire IAC to work correctly with the large throttle body. Any air leak or incorrect IAC travel setting turned into a higher idle. What I do like about closed loop with this current setup is how it can idle when it's cold or hot, electrical loads high or low, you have finer control over the idle. I also feed the gas tank vapor valve (240z 260z has this valve, I think. The 280z has a charcoal canaster) output and feed that in front of the throttle plate to burn the gas vapor off. When it's hot out the gas vapor would change the idle and AFR by two points. Having closed loop and AFR/EGO control corrects for that swing. Burning the gas vapor off from the tank. Do you need closed loop no, open loop can work just fine. If you want better idle control over different variables then closed loop can help with that, but it takes time to set it up from what I have found. The reason I went to Megasquirt or any modern ECU. I was tired of troubleshooting with a voltmeter and a closed system you could barely modify. Now I can tune at my computer and get real time data and logging to review your results. What a step forward, but it's been a long journey learning these features and how to apply them (incorrectly and correctly). I included my current tune and a data log. In the middle and end of the log you can see how it idles. Hope this helps. CurrentTune.msq 2025-05-21_16.32.19.mlg Edited May 25 by Datsunpowers Quote Link to comment Share on other sites More sharing options...
darom Posted May 25 Author Share Posted May 25 (edited) Thanks Tom for your recommendations. 1. sync loss - I noticed with my microsquirt (plus a few more guys on youtube), if I apply 'Burn' while the engine is idling, it would stumble/recover and will generate 1 sync loss error. I checked my driving log and didn't see any sync losses there. I am attaching my warm idle log, it doesn't show any errors either since I didn't apply any corrections. This stumble/burn issue might be related to microsquirt ECU limitations, I am not sure. 2. I re-adjusted my TPS while observing the throttle blade. Now I have 545 points in my throttle movement. The throttle blade is closed. 3. I set timing from 14.2 to 17 degrees. It looks like my engine doesn't mind, runs stable. 4. thanks for finding this TPS WOT curve - copied your settings. 5. my GM MAP sensor is showing 40 - 41 kPa at idle. I am at 873 feet in WI, which computes to 17.51 inHg. I got my mechanical vacuum gauge to double check - it was showing between 17 and 17.5 inHg (approximation). I feel much better. : -) 6. the lock/unlock option for sensors - I totally missed this one, it is locked now. I set the Top Dead Center a while back and confirmed it with my timing light (using 'Fixed' timing option in TunerStudio). I also re-adjusted my IAC valve steps per your tune. I will keep it as open-loop for now. I will do a data log for the car when the engine is cold. Appreciate the help! Den 2025-05-25_warm.mlg 2025-05-25-17degrees-idle.msq Edited May 25 by darom Quote Link to comment Share on other sites More sharing options...
Datsunpowers Posted May 26 Share Posted May 26 Den the idle looks better in the log you sent me. The AFR readings are steady not like before with the Accel firing off. I would make a couple more small adjustments to your tune. 1. Change your WUE setting from 220 down to 175 or 180. The WARM bit is not getting flipped and several functions use this bit to enable them including warm idle setting to tell that the engine is warmed up. The manual help is not clear what the setting is. When your thermostat opens or a little before seems a good setting to me. I set mine at 175. 2. EGO Correction, Active above Setting is set at 1300: You're not using EGO correction at idle. In the log EGO Cor1 is 100 at idle. It could be a choice you made I wanted to mention it. 3. Review your ASE Taper settings they seem high to me to keep adding extra fuel after startup. Take a look at the settings I sent you. I don't see any other big things out of adjustment from an idle perspective. The big thing you have at ask is how is it running? If its running good drive, it and enjoy. If it's not tweak it and see how that works. Good Luck, Tom Quote Link to comment Share on other sites More sharing options...
darom Posted May 27 Author Share Posted May 27 Thanks, Tom. The idle is smooth/predictable, without any oscillation. 1. WUE is changed per your config. I set it at 175F. 2. I left the EGO correction above 1300 rpm since my original thought was to prevent it from making changes to my VEs keeping a specific AFR there (13.5 - I am running batch injection, engine runs great with a healthy vacuum). Should I lower the EGO rpm limit from 1300 to 1100? I am still fiddling with the IAC stepper to lower my initial warmup idle. It jumps to 1600 rpm, I might move it to 1300 rpm by cutting the number of stepper steps. 3. Adjusted my ASE settings (percent/taper) I noticed that when the engine is hot, and I restart, my AFR is about 14.7-15 during the first 30-45 seconds. Then it goes back to my 13.5-13.9. Should I leave it alone or instead (this is my OCD is 'talking'), increase my ASE percent adder to a higher number to add a little more fuel (for ex., at 175F, from 9 to 15)? I will take the car for a test drive this week-end, will do a data log. Appreciate your suggestions! 2025-05-27-ASE-changes.msq 2025-05-27_17.45.45-hot-restart.mlg 2025-05-27_17.33.07-cold-start.mlg Quote Link to comment Share on other sites More sharing options...
Datsunpowers Posted May 30 Share Posted May 30 Den the only table you needed to flip the Warm bit at 175 is the WUE table all the other can have a higher temp values. Looking at the log the idle RPMs is on the higher side at startup and is lean. It could make the car stumble if you're driving it when it's cold. Since we are so close with our required fuel, between the two. I tweaked the startup and idle settings. Give this tune a try. 001_Startup _and_Idle_2025-05-30_05.55.19.msq Quote Link to comment Share on other sites More sharing options...
darom Posted June 6 Author Share Posted June 6 Thanks for the tune! I ordered a new IAC mentioned on the efi web site, for 1992 Grand Am 3.3L V6 model, walker products 21591012 (Tom, appreciate the reference). It has a different sharp pointed tip vs the ones I have (mushroom shaped). My IAC can barely control the idle, letting a lot of air by (poor seating position inside the PTZ's intake). It is also sometimes unpredictable - one day it will set the idle at 900ish, the other - over a 1000 rpm. I will update the thread once I install it. Quote Link to comment Share on other sites More sharing options...
darom Posted June 10 Author Share Posted June 10 I installed the new IAC, it seals the air bypass much better. It has a pointed tip (the Grand Am IAC is on the left, the right model comes with the Protunerz intake: I tried using Tom's tune idle air valve settings/steps (4-7-1, time steps + initial time step size + minimum steps to move), it worked on the bench in the beginning, but strangely once in the car, it refused to move and was stuck in one position. I put back my original (3-5-3) steps and it started moving. I am keeping 'Always on' setting as it works more predictably. I have a general question about these steps considering dozens of other combinations people use with their MS boards. Assuming the valve is the same, one car uses the Megasquirt board (dedicated IAC outputs) and another has a Microsquirt with the EFI Source's IAC stepper adapter (https://www.efisource.com/wp/shop/microsquirt-iac-stepper-adapter/), will the valve take the same steps in TunerStudio? I also tried both Homing Direction 'Open' and 'Closed'. The 'Closed' seemed to work better. The idle is stable. I found a set of informative YT videos at: https://www.youtube.com/watch?v=z43YPcDGQEQ on setting up the CLI (closed-loop idle) and will play around with it this week. Quote Link to comment Share on other sites More sharing options...
darom Posted June 21 Author Share Posted June 21 I set up the closed loop idle finally. This is the one of the best things since the invention of sliced bread. I still need to tune it, I will post my updated tune. I took the car for a test drive and noticed annoying loud rear-end noises going over any crack and pothole on the road. It is not clunking. My reverse gear is also hard to engage, I ordered a new clutch master/slave - it looks like the slave doesn't extend fully its rod, I think my clutch is dragging and my clutch pedal is out of adjustment. I will be replacing my mustache bar bushings and re-checking the torque of the locking strut nuts in the rear. Meanwhile, I decided to address my heat soaking issues with the intake, fuel rail and injectors. I found my old heat shield, bend it to contour the intake/exhaust ports and installed it. I checked with the remote temp gun, there is a 30F difference now (fuel rail/injectors were showing 170F): Quote Link to comment Share on other sites More sharing options...
A to Z Posted June 22 Share Posted June 22 clutch master. the rod that goes into it isn't going in far enough. the clevis needs to have a nut welded on to the end, with the thread aligned, and then the rod screws in only to the end of the nut. That little bit....3/8 of an inch, is what is keeping your slave from pushing far enough to work correctly. I had this problem and after asking and asking, I finally figured it out. Put a nut on the rod that you can run down and tighten against the welded on nut (screw the rod through the nut AND clevis THEN weld nut, so threads are aligned, then remove the bolt) Quote Link to comment Share on other sites More sharing options...
darom Posted June 22 Author Share Posted June 22 Cool, thanks AtoZ! I will check the rod length, if needed I will weld a nut to extend it a little. Quote Link to comment Share on other sites More sharing options...
darom Posted June 29 Author Share Posted June 29 Update: replaced the mustache bar bushings, re-torqued the strut lock nuts. I don't hear any more banging noises now. Still not sure what fixed it though. When I was checking my rear Bilsteins with springs compressed, I didn't feel any extra movements to give me that noise. I also swapped my master, slave clutch cylinders and clutch hydraulic hose. The old ones had some 'brake fluid sludge' inside from the internal leakage. I adjusted the clutch pedal at 8 inches (i have a carpet/sound insulation), the master cylinder rod of the replacement unit was the same length, no need for an extra nut. I could put the pedal at the max height (over 9.5 in) and the rod was still good. The free pedal travel is within specs, 15 mm. I was observing the operation of the slave with my $20 endoscope, 15 mm of the clutch pedal before the slave starts its movement. The clutch fork throw is half an inch (12.5 mm). I could push the slave's rod back towards the front, the rod gets back to its self-adjusting position. I did some searching - it sounds like 15 mm is a better number. My reverse and 5th get engaged without grinding noise and without any difficulty. The clutch operation is smooth. I used Rockauto's Luk's: LMC245 and LSC199 parts. Appreciate your guys' help. After fiddling with my closed-loop idle, I am still chasing my tail. I posted a thread on the msextra.com forum at: https://www.msextra.com/forums/viewtopic.php?t=82151 The RPMs get dropped very low, the ECU is not commanding enough steps for my IAC (or it is telling to give, for ex., 60 steps with not much difference). The car is driveable, but with rpms sometimes hitting low 300-400s, which is not good (CLI is not even running when it happens). Here is my updated tune and drive logs if anyone wants to take a peek. Thanks, Den 2025-06-29-v102.msq 2025-06-29-cold-start.mlg 1 Quote Link to comment Share on other sites More sharing options...
darom Posted July 3 Author Share Posted July 3 Update: I figured out why my RPMs were so low and the IAC wasn't adjusting its steps. My TPS in the Closed-Loop Idle PID Activation Settings, was set at 0.8. The actual TPS was 1.1 that day which meant that the CLI would never kick in when I was sitting in the car at idle. I re-calibrated it and decided to play it safe and set at 1.5. Today the car's CLI worked as intended. I am still dealing with wonky IAC which can be at steps 90 and barely allowing any air in. Also, I noticed that even if I select the MAT table to be used for reference, the ECU was still looking up the CLT settings. I posted this question on the msextra site, maybe it is a code glitch or this is how they designed it or I am missing another table. I might just use the CLT reference table and call it a day. I am posting the updated tune and the drive log. 2025-07-03_12.14.29-drive.mlg 2025-07-03-v104.msq 1 Quote Link to comment Share on other sites More sharing options...
Datsunpowers Posted July 4 Share Posted July 4 (edited) Den, I took a look at the log this morning. I have a couple observations vs. recommendations this time looking at the idle sections only. 1. The TPS varies from 0 to .5 and I think this is causing other issues. Do you think the throttle plate is hitting the throttle screw stop every time or the butterfly is not closing correctly every time? Could it be electrical noise. Does the throttle cable has slack in it? At the start of the log its .02 at the end its .05 one time. Looking at my setup it only varies .01 at idle and has a very stable TPS reading. 2. At 16.833s the timing jumps 6 degrees because of the Idle adaptive advance timing is firing off. Why I am not sure. 3. At 26.433s the Accel enrichment is firing off with a PW spike of 15.5 and then a Timing advancement, but I could NOT see why in the accel enrichment table. Now the timing advancement could be cause by the spike in fuel and then the dip in RPMs. I think this issue need looked into. This should not fire off at idle. 4. At 93.905s the Accel enrichment is firing off with a PW spike of 14.5 and then a Timing advancement, but I could NOT see why in the accel enrichment table. Now the timing advancement could be cause by the spike in fuel and then the dip in RPMs. Again, I think this issue need looked into. The idle controls are different on the Microsquirt vs. the Megasquirt so I don't understand all the settings, but I hope what I found gives you and area to look at. Edited July 4 by Datsunpowers Quote Link to comment Share on other sites More sharing options...
darom Posted July 5 Author Share Posted July 5 Hi Tom! 1. I ordered another TPS sensor (different vendor) to test. I also noticed that it is not 100 percent stable. I am using the sensor ground for it per microsquirt manual and the 5V feed. My throttle blade is completely closed, the spring is strong in this Protunerz' throttle body. I do have a throttle cable slack. 2. I think what is happening at 16.833, is that for -200 rpm correction per the 'Idle Adaptive Advance Timing' table, it will kick 6 degrees of timing. My running RPMs are 996, when the target is 1200. So the ECU is adding 6 degrees to raise the RPMs. When the RPM of 1200 is matched, for ex., at 27.366sec, the correction advance is almost at 0 degrees, 0.6 actually. 3. At 26 seconds, i was backing out of the garage in reverse, with almost no TPS input. No sure what is happening here either. I also see a -280 RPMdot that follows. 4. At 93sec, there is a TPSdot of 14, maybe this is why my AE is enabled? My target RPM is 1183, the running RPM is 972, I see the Idle Correction Advance is adding another 6 degrees. I am wondering if I should move from 6 to 3 degrees max for CLI control? It might be too much of a change to adjust the RPMs? I will try that and will make another log. Overall, the CLI is the most confusing part for me. When it finally started working (kind of), it surely made my day :-) Appreciate you taking your time checking out my progress! I do have a few questions for you - per your tune: a. you have Shift Settings -> Leave Valve Closed Above:(rps) - 7,000, For this number of seconds - 0. Basically, you don't want the IAC valve to close at all? Any benefit from this setting? b. you are using the table for CLT in the CLI Settings (Use CLT or MAT In Table Lookup). Do you have any heat soaking issues? I read some posts where it was advised to use the MAT table. Any other benefits? Should I use the CLT table as well? I asked the question on the msextra forum why the ECU still checks the CLT table, but no one has responded yet: https://www.msextra.com/forums/viewtopic.php?t=82151&sid=ccd10333b5cfba1911eaded17a655060 Thanks! Den Quote Link to comment Share on other sites More sharing options...
darom Posted July 6 Author Share Posted July 6 (edited) Update: Today I worked on correctly setting up the initial target RPM table. Took two readings per each rpm step, in my case, 850, 950, 1100, 1200 and 1300, when the car was semi-warm and hot. Then added another 10 percent per: https://www.diyautotune.com/support/closed-loop-idle-pwm/ Then from 100 to 170, interpolated vertically. Since I didn't know what steps would be at lower temps, left them the same at the bottom: I switched to using CLT table (not MAT) since I am still clueless where I can find it (unless TS uses the same table for both and it will be just different temp ranges there). I also noticed at hot restart, the AFRs are very lean, 15-16 range due to the injectors getting heat soaked. Searched on the msextra, found some posts about guys using a band-aid fix by adding ASE and taper at higher temperature. I experimented with mine and added some: It does help somewhat in the beginning. I added EGO correction of 8 percent above 800 rpms. This helps as well, and my AFRs get back to normal range. I am posting my updated tune, plus the idle log. I haven't taken the car for a test drive yet. 2025-07-06-v106.msq 2025-07-06_10.40.07.mlg Edited July 6 by darom Quote Link to comment Share on other sites More sharing options...
Datsunpowers Posted July 12 Share Posted July 12 (edited) Den here are the answers to your two questions. 1. I didn't think (Leave Valve Closed Above:(rpm) - 7,000) would make any different so I kept the default. 2. I haven't had any hot start issues as my hood has two rows of louvers in it. They came with the car when I bought it. I think this really helps with starting and keeps the under-hood temps down. Looking over the log at Idle I would fatten up your fuel at idle more to bring down the AFR. If you look at your EGO Correction the max it can correct is 8% starting at 40 seconds in. It continues to run at the max correction at 108% during the log you sent. You could add an EGO Correction gauge on your dashboard and monitor how close it is to your target AFR and adjust your Fuel VE table 1 until your AFR Correction is at 100. Currently your AFR target 1 is set to 13.7. Here is what my gauges look like on my main dashboard. Hope this helps, Tom Edited July 12 by Datsunpowers Quote Link to comment Share on other sites More sharing options...
darom Posted July 14 Author Share Posted July 14 Thanks, Tom, will add a little more fuel. I noticed my cold -> warm cycle follows a pretty predictable AFRs curve per the table and my manual tuning I did at idle a while back (I was aiming for 13.5-13.7). Things go out of wack somewhat when I restart a hot engine, the AFRs are leaner until they stabilize later on. Quote Link to comment Share on other sites More sharing options...
