starter whoes
man thats weird it should work the flywheels both have the same size od and i think all the starter have same pinion gear did you take the spacer of the back of the crank when you removed the old flexplate i'm sure you did other than that it should work are flywheel in good shape
Yes, there is a 6 bolt "washer" between the flywheel bolt heads and the flywheel, but also a "cap" on the end of the crank of the automatic models that needs to be pried off in order to mount a flywheel.
It would be very obvious in assembly, as the flywheel could not be centered and hung on the crankshaft - the OD of the cap will not go into the relief of the flywheel, and the flywheel would stand off the crank about the width of the ring gear.
