How good Is A T26 Turbo
I just got a T26 Turbo from a 7M-GTE And I was woundring if it would be good on my L28 Motor and what kind of horsepower gain would I get out of it? ugg.gif and how would I set it up?
(stock 280zxt compressor up left, 50 trim to right top, CT26 bottom)
The CT26 is larger than a stock T3, but smaller than most T4s. Supra Turbo came stock with 240hp at 6psi of boost. The CT26 tops out at around 15psi, which is enough to make the 7m-gte put out around 300hp to the ground. SSS510 is running 11's with a stock one on his stroked L28ET, he's also running NOS, but no intercooler.
The waste gate hole is noticeably larger, and the compressor fin design is much different, probably a more modern design. The compressors can be honed out to fit a variety of garrett comprssors and turbines to fit your horse power needs up to 650hp keeping the stock housings. http://www.turbochargers.com/TurboUpgradecatalog/TOYOTACT26STOCK.htm
Socalsupras.com has a list of people running 1/4 mile times with stock and modified CT26 turbos. When looking at the 1/4 mile times remember that these cars weigh 4000 pounds!!!
http://www.socalsupras.com/race.htm
It won't bolt right up to a t3 turbine flange, but with a little work anything is possible.
