Installation of Holley Sniper 2 EFI and NX Nitrous M1000 install on my Draw through turbo stroked L series
A to Z
Well, thanks!  I appreciate it.
it's a build in progress, from SU's on a stroker, to a Crown turbo kit in pieces..... that I customized the majority of for a DIY setup using a motorcycle Mikuni HSR 45 with a flat slide, to now EFI.  I am just improving the system I have had, 1 step at a time.  The Nitrous is just for looks.  If I were to use Nitrous with the turbo, I am not sure the engine would survive......its fully forged, but throwing 2 power adders at it at the same time?.........Eh
08-21-2025 Day 2 progress pics.  Fuel system fully installed and wired up in the rear.  Same for engine compartment. One pic you can see I abandoned in place the old fuel lines up in the trans tunnel.  You can see the T fitting I installed where the nitrous line can be installed at a future date when I'm ready to melt my engine down.  The temp sensor that comes with the Sniper 2 is too large, ONE other company makes one, and it's a very small one, smaller than the size I need to screw in.  If I screwed it into a bushing there wouldn't be enough of the probe sticking into the stream of antifreeze to work right, so what I had to do was cut a bushing down on both sides.  I tried to thread it on, but it wouldn't budge, so I ground down the threads on the smaller probe and got the bushing (which was now basically a sleeve) to fit over it.  I JB Welded it together, and by tomorrow it should be ready to install.  Wiring awaits me and some other little do-dad's, and the finish line is within sight.  I had to change my air cleaner, as the round one was too high and hitting the hood.  No one makes a thin air filter for it.......So I went with the tried and true Edelbrock foam one, and it clears.  Here are some pics:
