A to Z Posted August 17 Share Posted August 17 Day 1 of installation. almost 12 hour day and got a lot knocked out. Pics below: 2 Quote Link to comment Share on other sites More sharing options...
Mitchel0407 Posted August 18 Share Posted August 18 Just curious, what made you go with a draw through setup instead of port injection? That saying I love the clean installation! 1 Quote Link to comment Share on other sites More sharing options...
A to Z Posted August 19 Author Share Posted August 19 Well, thanks! I appreciate it. it's a build in progress, from SU's on a stroker, to a Crown turbo kit in pieces..... that I customized the majority of for a DIY setup using a motorcycle Mikuni HSR 45 with a flat slide, to now EFI. I am just improving the system I have had, 1 step at a time. The Nitrous is just for looks. If I were to use Nitrous with the turbo, I am not sure the engine would survive......its fully forged, but throwing 2 power adders at it at the same time?.........Eh Quote Link to comment Share on other sites More sharing options...
A to Z Posted August 21 Author Share Posted August 21 08-21-2025 Day 2 progress pics. Fuel system fully installed and wired up in the rear. Same for engine compartment. One pic you can see I abandoned in place the old fuel lines up in the trans tunnel. You can see the T fitting I installed where the nitrous line can be installed at a future date when I'm ready to melt my engine down. The temp sensor that comes with the Sniper 2 is too large, ONE other company makes one, and it's a very small one, smaller than the size I need to screw in. If I screwed it into a bushing there wouldn't be enough of the probe sticking into the stream of antifreeze to work right, so what I had to do was cut a bushing down on both sides. I tried to thread it on, but it wouldn't budge, so I ground down the threads on the smaller probe and got the bushing (which was now basically a sleeve) to fit over it. I JB Welded it together, and by tomorrow it should be ready to install. Wiring awaits me and some other little do-dad's, and the finish line is within sight. I had to change my air cleaner, as the round one was too high and hitting the hood. No one makes a thin air filter for it.......So I went with the tried and true Edelbrock foam one, and it clears. Here are some pics: Quote Link to comment Share on other sites More sharing options...
A to Z Posted August 24 Author Share Posted August 24 Day 3 EFI install, almost done! Quote Link to comment Share on other sites More sharing options...
A to Z Posted August 24 Author Share Posted August 24 1 Quote Link to comment Share on other sites More sharing options...
A to Z Posted August 26 Author Share Posted August 26 I got in a little bit of time on the EFI project today. re-ran my water meth lines....the way I had them was problematic.....kept trying to pinch the lines. Also figured out how to run a brace from the engine to the carb intake. I have some heim joints and 3/8" all thread....will come off of one of the 10mm smog pump holes in the block and then up to the bolts in the back of the intake. Small steps. Quote Link to comment Share on other sites More sharing options...
A to Z Posted Tuesday at 06:41 PM Author Share Posted Tuesday at 06:41 PM I was able to squeeze in a little time today and build a brace to hold my carb and intake up. Heim joints and all thread. 1 Quote Link to comment Share on other sites More sharing options...
A to Z Posted Friday at 06:27 AM Author Share Posted Friday at 06:27 AM I disconnected my throttle cable and lubed it up, now it moves freely with no drag, in doing so, I re-arranged some of the items attached to the carb thus cleaning it up. A short amount of time to work on stuff today and I'm happy I was able to get it done. Also was able to tighten the spring for the secondary butterflies which is basically required to keep them working right. My thermostat probe adapter that goes into the top radiator hose also arrived and snapped a few pics. Quote Link to comment Share on other sites More sharing options...
A to Z Posted 22 hours ago Author Share Posted 22 hours ago Day 4 of EFI install complete. ALL DONE. Time for remote tuning. pics and 2 videos at the end V1.MOV V2.MOV Quote Link to comment Share on other sites More sharing options...
A to Z Posted 21 hours ago Author Share Posted 21 hours ago Ok, so update....thanks to those who warned me about these Edelbrock foam air cleaners. I started reading, one back fire and they will catch fire and turn into goo and run down into your carb/TBI !!!!! oh no! So, i looked online, because this filter was also hitting my hood. I found this company: Pro Series Screens - Intensity Racing Products I bought the mesh screen to work on my carb mouth. So glad you guys said something. WHEW! see pic, I got the low profile with the single hole.. 98 bucks....115 shipped. Saved my life. Quote Link to comment Share on other sites More sharing options...
Enzo250gto Posted 4 hours ago Share Posted 4 hours ago Hi mate, Low profile alloy air cleaner top with a carbon fibre air cleaner with the collection point in front of the radiator. Flexible rubber joiner between the alloy top hat and the carbon fibre air cleaner. The alloy piece is only about 2.5 inches high. Just another idea for cold air induction. Regards David. Quote Link to comment Share on other sites More sharing options...
