jeffer949 Posted October 8, 2025 Share Posted October 8, 2025 Im building a l28et and im converting it to front sump. I've already drilled everything and I know what im doing there. Wanted to run how im sealing the oil galley off. I the picture you can see my new pickup hole and dipstick hole. I have already put a Welch plug to the left of the small hole and plugged the old pickup. Next im going to put the aluminum plug i made that has a npt plug inside of it between the new pickup and dipstick hole. When I tighten down the npt plug it will spread the outer wall of the aluminum plug and seal it off. I will theb back that up with another Welch plug. Im almost sure it will work but I wanted to get some more eyes on it to make aure. Because if it doesnt work. Ill suck air and take out the bearings. Any recommendations on a sealer I should use if any? Quote Link to comment Share on other sites More sharing options...
jeffer949 Posted October 20, 2025 Author Share Posted October 20, 2025 Well. The above mod worked and its now front jumped. Had to make a new dip stick tube and then I started on making an adjustable cam gear. Turned the inner bore out and faced the rest so ill have a good flat surface for the aluminum inner hub to bolt to. I realizing noone answers questions on here anymore and people just use it for documenting their builds. Its really sad. Quote Link to comment Share on other sites More sharing options...
calZ Posted October 21, 2025 Share Posted October 21, 2025 I answer questions whenever I've got a good answer, but I haven't tried enough different sealers to be comfortable risking your engine on my recommendation. Quote Link to comment Share on other sites More sharing options...
jeffer949 Posted October 22, 2025 Author Share Posted October 22, 2025 I'm not complaining to anybody specific. Ive been around this site for close to 20 years and back in the day it was so helpful. Now its dead. Is what it is. Quote Link to comment Share on other sites More sharing options...
calZ Posted October 25, 2025 Share Posted October 25, 2025 Oh I know, I just meant that most people only speak when they've got a good answer, and there are fewer people around now, so you're going to get fewer answers. It does suck how little activity there is these days. A lot of the experts aren't around anymore. Quote Link to comment Share on other sites More sharing options...
FastFloridian Posted October 25, 2025 Share Posted October 25, 2025 There is still a few around (I’m not one of them). I’ve gotten some good advice. At least this site is still up, the 370Z site just went down a few weeks ago, ugh. Quote Link to comment Share on other sites More sharing options...
jeffer949 Posted December 2, 2025 Author Share Posted December 2, 2025 Slowly been chipping away at building this engine. Got all the oil pickup tube mods done. Then used my cnc router to plot out where to drill my block for the cooling mods for JeffP's head gasket. I'm cheap and not using his gasket but modifying a felpro to have all the cooling passages. My router isnt ridged enough to actually machine the holes but it allowed me to do a spot drill for the hole centers. Then came back and use the correct sized drill bits in a hand drill. Then used a die grinder to connect the 2 holes on the oblong holes. Worked well. Some time after that i was working on m wife"s car but wanted to keep going on the engine so I took my heavily carboned up pistons and soaked them in Superclean. DO NOT do this!!!! It eroded my pistons and made them unusable. Talk about a gut punch. The pistons where within spec and perfectly usable. Well I didnt know what I wanted for Christmas But I did after this. My mom and Aunt said they would go in together and get some new ITM's for it and where nice enough to let me have them now. Pressed the old ones off. New ones on. Gapped the rings. And install. Quote Link to comment Share on other sites More sharing options...
jeffer949 Posted December 2, 2025 Author Share Posted December 2, 2025 Next I need to pull my current engine as I need the oil pan from it along with the new timing chain guilds and oil pump and everything else. Thats new from when i built it a year or so ago. With it being a front sump I'm going to look into adding some oil baffling of some sort. I cant remember if there is any. Need to button up my 4n71b Jatco from the 84 300zx turbo and finish the inner hub for my adjustable cam gear. But I cant finish that till I pull the old trans as I need the bellhousing. Then I go down the rabbit hole of needing a new driveshaft but also wanting to swap in a 8.8 out of an ford explorer... .. 1 Quote Link to comment Share on other sites More sharing options...
Wjbrooks11 Posted March 9 Share Posted March 9 (edited) Jumping in here, I am also currently swapping my L28 to front sump and had a few questions. What oil pan are you using? I found a maxima diesel front sump pan. For drilling the dip stick tube, did you go through the oil passage the rear oil pickup uses? I extended the oil pickup tube rather than drilling the front one out, and I'm concerned the dip stick with interfere with the oil flow. Thanks! Edited March 9 by Wjbrooks11 Quote Link to comment Share on other sites More sharing options...
jeffer949 Posted March 27 Author Share Posted March 27 If your extending your oil pickup you can not drill the front dipstick tube hole. it goes straight through the oil galley. I was able to do it as i plugged mine first. You will have to make a dip stick tube holder in your oil pan. I drilled my block as Im way better at machining than i am at welding. What are you working on that you are front sump? Quote Link to comment Share on other sites More sharing options...
jeffer949 Posted March 27 Author Share Posted March 27 Im using the stock maxima oil pan. The diesel maxima pan should work also. It actually has more volume i believe and has a place to drain your turbo into also!!! Quote Link to comment Share on other sites More sharing options...
jeffer949 Posted March 27 Author Share Posted March 27 Looking at your pictures make sure that the oil pickup is parallel to the oil pan bottom. With it angled like that its going to be a ways away from the bottom of the pan. Quote Link to comment Share on other sites More sharing options...
HowlerMonkey Posted Thursday at 06:48 PM Share Posted Thursday at 06:48 PM Some maxima oil pans have "wings" but most I've seen were simply front sump. Quote Link to comment Share on other sites More sharing options...
jeffer949 Posted Saturday at 02:52 PM Author Share Posted Saturday at 02:52 PM On 4/2/2026 at 1:48 PM, HowlerMonkey said: Some maxima oil pans have "wings" but most I've seen were simply front sump. I believe the winged maxima pan is the diesel pan Quote Link to comment Share on other sites More sharing options...
