JTR Passenger side offset
Guest Locutus
Guest Locutus
why does JTR offset the engine to the passenger side, wouldn't it make more sense to go straight down the middle of the car?
Thats correct. Both are offset the same amount. This does several things... allows for the same driveline alignment side to side, and it also allows for less re-engineering of the factory mount position on the frame. The other points made above are also true. Weight bias to counter the weight of the driver.
Mike
"I will not be a spectator in the sport of life!"
mjk
