Welding stainless steel
Jason81NA,82RBtt
Use a wire welder with argon mix with either regular wire or.... stainless wire may be best. a small spool of stainless wire is not that expensive
309L is good for mild steel to stainless, but isn't the exhaust crap cast iron? If so, you need a nickel rod tig or stick. The O2 bung is not load sensitive so most anything will be fine. If is is mild steel(exhaust) to 304 then JohnC is correct and if it is 321 to mild steel then a 347 rod is preferred.
