Would this be considered Restricted?
Opps
.518/.536 VL
60 degrees overlap
Sportsman 2's (200cc, 64cc) pocket ported
2750lb car
The exhaust :
1 5/8 block huggers
2 1/2 y
3 Pipe out to stock position
Not mandrel pipe some places the cross-section gets pretty tight.
Sounds very similar to mine. You shouldn't have problems (I don't).
You'd get the most benefit from going to long tubes, but you really don't need them. I run mid 12's and my engine has some serious intake limitations right now. Don't worry about it.
Couple of the new hot rod type mags I read have had an exhaust pressure test system. Comes with a drill bit, a tap, bunch of pipe plugs (to fill the holes you drilled...) and a test gauge. Shows how you can test at various points in your system to determine where and how much restriction exists. Seems like a good idea. $50 was the cost. I think the new Chevy High Performance had it for a reference. Email me and I'll try to find it for you if you want.
