Miles Posted March 8, 2002 Share Posted March 8, 2002 Our 350 sbc surges. It has a new Edlebrock carb. It's not like a hicup. More like it speeds up slightly then slows down so it feels like a pulse. It is most noticable when holding constant speed in first and second, but can be felt in all gears. Initial throttle reponse is slightly slow once the engine is warmed up. Fuel pressure runs about 3psi average. I was thinking it might be fuel pressure related, but when I floor it hard it really takes off without any hesitation. It does not seem to be starving for fuel. Any help would be appreciated. Thanks Miles Quote Link to comment Share on other sites More sharing options...
pparaska Posted March 8, 2002 Share Posted March 8, 2002 Sounds like a typical lean surge. Have you tried changing the rods/jets/etc? Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted March 9, 2002 Share Posted March 9, 2002 Surging problem: I agree. It may be a lean surge condition. Carter has assortment of rods and jets for your AFB carb. Note what jets and rods you start with then slowly to either smaller rod or bigger jet. If the problem occurs only at cruising speed and no load, this should solve your problem. If it occurs when under load, then you should play with the power piston springs. Using a hand vacuum pump will make it easier. If you still can't get it right, you can install air fuel meter and make adjustments accurately. This will also allow you to get maximin fuel mileage. Sunny Quote Link to comment Share on other sites More sharing options...
Miles Posted April 10, 2002 Author Share Posted April 10, 2002 Fixed the lean surge problem. Changed out the Edelbrock metering rods one step in the rich direction and it accelerates fast and smooth. Although at idle the engine speeds up and slows down slightly now. Thanks Miles Quote Link to comment Share on other sites More sharing options...
Guest HIGHRPM Posted April 12, 2002 Share Posted April 12, 2002 Originally posted by Miles:Fixed the lean surge problem. Changed out the Edelbrock metering rods one step in the rich direction and it accelerates fast and smooth. Although at idle the engine speeds up and slows down slightly now. Thanks Miles MILES. In all the years that I've built street small block motors, my fuel pressure always was between 5 to 6 lbs.The fuel pressure for the stock inline six was 3 to 4 lbs. Try increasing line pressure to 5 lbs. Most 4 barrels carbs took around 6 pounds before they needed a regulator.Hope this helps. ROD Quote Link to comment Share on other sites More sharing options...
Miles Posted April 12, 2002 Author Share Posted April 12, 2002 Highrpm Thanks. I'll add this to my do list. Miles Quote Link to comment Share on other sites More sharing options...
