Transmission rebuilt kits/parts
Z_Dust
usually when you get a used trans it has a bearing howl from running low on oil.there is a small seal in speedo gear drive that leaks.usually if you repair your own trans and isolate what part is worn nissan parts arent that expensive.but if you open a trans up and its missing teeth on the countershaft cluster its toast.somtimes i take 2 trans and make 1 with some new bearings and seals.
randy, is this seal replaceable? im leaking out the speedo gear i think, i leak enough trans fluid to worry about it and im sure its not the fill or drain holes, im also missing the lock thing too, ill get them all this friday at pnp, but i would like to replace that seal with a fresh one.
