R180 to R200 Woes... pleazzzz help :(
Heres my story first in a nutshell..
broke R180, went R200, installed R200... R200 no fit,
make R200 fit by installing it incorrectly, works but
makes noise..
I know this isnt in the correct forum but I know you
guys can help me out.. if anybody can... I have been
doing an R200 conversion on my 74 1/2 260Z for over a
year now.. LOL and its pretty sad I know.. hehe
I have been reading posts in the Drivetrain section about
R200 swaps all night long, and I cant find the valid info im
looking for so I outcry to the Z community... :)
I got a new-used R200 from a salvage yard (pretty respectable
place ALL Z East) and installed it (well.. converted it from an R180) and
ran into some nasty problems getting it to line up and fit.
And when I did finally find a way to make it fit, it made growling noise
at sub-freeway speeds right from the beginning... bummer eh, install
new rear end and it makes noise... BUT, only if I
let off the pedal... if the pedal is applied, the noise stops
completely...
When I got the R200 into position while installing, and tried to line it up
I discovered that the whole diff was too far forward
(towards the engine) by about 3/4 inch (in the stock position) and
the rear arms cannot bolt up atleast this is what I am seeing.. :(
From the Rear of the car looking at the mustache bar
this is how I believe it should look... with the mustash bar set
forward (towards the engine) and the hangers further back?
The mustash bar SHOULD NOT touch the rear "traverse link"
crossmember hangers at all correct?
A. Example A is how I believe it should be (but wont fit)
@___| |___| |___/@
____| |___| |____/
_____| |___| |____
This is how the original placement is correct (fig A) Mustash bar
sits IN FRONT of the hangers by a cpl inches, doesnt touch them?
B. Well....This is how I ended up putting it in...
@__|_|___|_|__/@
_____________/
____| |____| |_____
Its a crude drawing but you can see the first one is
in front and the second one is behind the hangers..
This is how I ended up bolting it up, with the Mustash
bar wedged TIGHT Behind the two hangers, I
managed this by pulling out the mustash bar and flipping
it around completely.....
this was the ONLY WAY I could get the diff to sit far
enough back to line up (somewhat properly).
I mean its wedged pretty darn tight up against those
2 hangers, and the bar doesnt sit flush on the hangers
either, its kinda kocked alittle bit and doesnt sit good.
With it like this (figure B.) how I installed it... the rear end
makes noise when I let off the pedal at sub-freeway speeds,
I think the U-Joint or Pinion Flange angles are being thrown off by how I
had the mustash bar positioned so tightly against those
hangers... I think its out of alignment this way.
I guess my questions are (does my illustrations make any damn
sense whatsoever?) LOL and if they do make sense
what do you think?
Is it ok for the mustash bar to sit behind the hangers? wedged
up tight like I have it? and if this is not the root of my noise
problem, could that problem be just a bad diff? And the
placement was ok all along?
Thanks alot, any suggestions, ideas, slaps in the face
with reality will be greatly appreciated...
dannadeau2112@hotmail.com if you would
like to email
Dan
Portland Oregon
Hey Mike,
That is a very good question... I went to the boneyard and
got another mustash bar the same day I bought the R200, I
asked for a R200 bar, they gave me one..., I got home.. and
it was the same exact bar I had on with the R180.
So there is a noticable difference in the 2 bars?
so if the bar I pulled off my bad R180 and the bar I picked up
at the junkyard were both exactly the same (and they were) that
means my mustash bar is wrong? I bought a R180 bar from
the beginning... that is very depressing... LOL
do you know anywhere I can see a side-by-side comparison
of these 2 bars?
DAMN!
Thanks
Dan
Yes, the bolt spacing for the studs on the rear of the R180/200 are not the same. Did you have to drill holes for the R200 to fit in the moustache bar? The studs should be closer together on the R180, and if it was exactly the same as on your R180 they gave you the wrong one.
R200 bar is also beefier.
Comparison on this page:
http://www.geocities.com/madmanadam/Z-car/r200swap.html
Now im stumped... I think I have the R200 bar... but, I have a question.
there were 2 kinds of 260Z which both had R180's, the earlier
and the later, the later... 74 1/2 used some different parts which I
am assuming were from the 280Z... now, do you know if one
of those parts was the beefier R200 mustash bar?
and maybe this is why my R180 bar and the R200 bar I
got from the junkyard looked the same?
Or did all 260's use the R180 bar? And the holes... I
never drilled anything, are you certain that the R180 bar
wont fit on an R200 diff?
if this is the case for sure, then I know I got the right
bar, cuz I didnt drill any new holes.
This is pretty frustrating, but that website looks like a good
reference... I like the crossed out title "my R200 swap that failed"
heheh I can feel that.
Dan
The R200 bar will fit behind the 2 plates coming down behind the diff (mounting points for the rear pickups of the rear control arms), the R180 fits forward of those two plates. Also, the R200 bar is thicker than the R180 bar.
Tim
Hey Tim,
I can see in those pictures on that website that the R200 is sitting IN FRONT
of those 2 plates... that was one of my biggest questions.
Now that I know, I need to figure out why my diff is making
noise while installed that way.
The fit up against those bars isnt that great, and thats why I felt
that it wasnt quite right... cuz if you look at the mustash bar as
it contacts those plates.. it doesnt sit flush. its kinda kocked
angular alittle bit and looks kinda funky. And I know the R180
didnt sit like that.
as far as the diff making Noise only at 45-mph and ONLY when I
let my foot off the gas... do you think its a shot bearing in the diff
or more likely a problem with the ujoint angles or pinion flange
driveline angle?
Thanks for all your help.
Dan
Nope, the R180 and R200 were notably different, in size and weight... but I SWEAR that the mustash bars were identical!!! weird. how can this be?
im going to have to take a few more looks at my mustash bar, is Mudge correct to say the R180 bar wont even adapt to an R200 due to hole differences?
im confused, I think I have the R200 bar... I probally have everything right the first time and I bought a shot diff. :evil:
Dan
I know why your r200 sits about 3/4" to far foward. Because I did the same thing! Flip you front diff mount the other direction and all will be cured! It will push the diff back the 3/4" and give the the proper clearence to bolt everything back up!
