yo2001 Posted March 28, 2003 Share Posted March 28, 2003 I was looking at the R200 LSD unit from S14/S15 silivia on ebay I was wandering if the ring and LSD unit can be fitted with a S30's pinion gear and R200 housing? Is there a different pitch on the pinion gear? I'm think if it works, I can get the 11 teeth pinion and 4.11 ring to get 3.70. Quote Link to comment Share on other sites More sharing options...
240Z Turbo Posted March 28, 2003 Share Posted March 28, 2003 Not possible, diff is shorter...pinion gear won't work....to short for our longer diffs. Quote Link to comment Share on other sites More sharing options...
yo2001 Posted March 28, 2003 Author Share Posted March 28, 2003 Yeah, the 240sx diff's are the pumpkin right? How about if I used the S30's pinion and rings adapted to S14/S15's LSD unit? Quote Link to comment Share on other sites More sharing options...
Dp351zcar Posted March 28, 2003 Share Posted March 28, 2003 A ring and pinion have to be used and replaced as a set. The VLSD carrier can be taken out of the S14 housing and put into a old style s30 R200. It will cause some head aches. You will need to get a 87-89 R200 so it will have 12mm ring bolts or make some spacers to make it fit. That will not be the biggest problem, the VLSD takes diffrent side stubs than the old R200. They are diffrent lengths and the retaining rings are in diffrent places. I spent some time last night helping a friend put a helical carrier out of a S15 into a S32 housing to put in his S14(?) (240SX). It fit so it will also fit a old style R200 it just needs it's own style of side stubs as they are bigger and have more splines. Don Quote Link to comment Share on other sites More sharing options...
Sparky Posted March 29, 2003 Share Posted March 29, 2003 funny to see this thread. check it out: i knew that the stubs would be a major problem....but i got lucky and came across this one with stubs. so there you have it. ill be using the CVs from a 240SX/300ZX combo in a later R200 housing. lots of work...but for the price i paid...i cannot go wrong. laterZ Quote Link to comment Share on other sites More sharing options...
Dp351zcar Posted March 30, 2003 Share Posted March 30, 2003 That is the same carrier that comes in a na Z32. Don Quote Link to comment Share on other sites More sharing options...
