flow difference between 50 and 60 trim T04E housing
yo2001
what would be the flow difference between 50 and 60 trim T04E housingWith same wheel? I guess at the same boost level too. I'm thinking 50 trim compressor housing with .50 trim wheel. I wante to see if there is a benefit from running 60 trim housing with the same wheel. :?:
Are you confusing A/R with trim? A/R is the housing spec and the trim has to do with the wheel characteristics...least that's what I thought.
Are you talking about a 50 trim with a .5 or .6 A/R housing, or a 60 trim wheel with the .5 or .6 housing?
