Got the Idea ?
Guest CS_280ZX
Guest CS_280ZX
:roll:
Hi all, i am asking to see if anyone has made some small tweaks on a 1979 L28 series ( stock ) engine that has increased either fuel economy or power.
anything at all, pref without spending any money as such.
Cheers.
Carl.
Guest Aaron
Yeah, what SleeperZ said, but don't use platnium plugs on the L motor. I have never had good luck with them on a Japanese engine. Don't forget the cap and rotor button also.
All you need to index are some one those little spacer washers, and a sharpie. With the dual electrode plugs, it is easy as pie.
FWIW, I used to use the NGK racing plug for the 300ZXTT, and it did not run well in my car. My "buddy" who owns a shop sold me a set of 6 copper bosch dual electrode plugs, and that fixed the surging I got with the NGK's, but when I went to replace them I found out my "buddy" did not know what he was doing, the heat range was a 2, and stock is a 7. Higher numbers equate to a colder plug.
So I had my parts guy look up a heat range 7 dual electrode, and came up with the M3 plug, and it works great. I have run in excess of 20 psi with it at its preset gap, and a stock 300ZX coil with no misfires. I use Jacob's plug wires.
