72zcar Posted May 15, 2003 Share Posted May 15, 2003 I am about ready to buy the carter fuel pump for my v8z. I see in the summit catalog the are two that might for my stock 350. Should I get the 5 psi street pump part number crt-p4070 or the 7 psi street strip crt-p4594? And is the 7 psi 4594 louder than the 5 psi pump. Also, is a regulator required for these pumps? thanks, bob Quote Link to comment Share on other sites More sharing options...
Heavy Z Posted May 15, 2003 Share Posted May 15, 2003 check it out...im thinking.. why is it ok for bird irritating sound people to need to make normal people to be tortured and made to feel like the irritation is the proper punishment for the normal people. Huh?!? Maybe you could re-phrase that last part... I've got the 5-7 psi carter and yes you should run a regulator. Make sure you mount it strait or they can sing like a banshee. Quote Link to comment Share on other sites More sharing options...
72zcar Posted May 15, 2003 Author Share Posted May 15, 2003 well maybe Im not normal... but I hate irritating birds and trees. What is the part number on your carter? summit has a 5 psi and a 7 psi but I don't see a 5-7 psi pump Quote Link to comment Share on other sites More sharing options...
Heavy Z Posted May 16, 2003 Share Posted May 16, 2003 Oh, sorry I got mine at Jegs and I was wrong about the flow, it was the 6-8 psi version. At summit it's the 7 psi street/strip pump. Thanks for the explanation on the birds - get a cat that likes to climb and you're set. Good luck wit da gas pumper, bro. Quote Link to comment Share on other sites More sharing options...
72zcar Posted May 16, 2003 Author Share Posted May 16, 2003 I have the holley blue right now and It is tooo loud I have heard the carter is much quieter, how loud is yours? My holley blue sounds like two lesbians going at it with giant vibators in the back of my z... Quote Link to comment Share on other sites More sharing options...
Heavy Z Posted May 16, 2003 Share Posted May 16, 2003 Hard to say how loud it is, I don't notice it w/ soundproofing and a fairly noisy exhaust system. Quote Link to comment Share on other sites More sharing options...
Tim240z Posted May 16, 2003 Share Posted May 16, 2003 My holley blue sounds like two lesbians going at it with giant vibators in the back of my z... You have a frame of reference for this? Tim Quote Link to comment Share on other sites More sharing options...
72zcar Posted May 17, 2003 Author Share Posted May 17, 2003 I'm going to get the street/strip carter then... I can't stand the lesbians in the back of my z .. Quote Link to comment Share on other sites More sharing options...
Georgia Flash Posted May 18, 2003 Share Posted May 18, 2003 I purchased the Carter Competition Series Silver pump from Jegs and it does not need a regulator. http://www.jegs.com/cgi-bin/ncommerce3/ProductDisplay?prrfnbr=3210&prmenbr=361 I used the original Datsun mounting bracket and housing slightly modified. It fit pretty good after a little trial and error. I couldn't get the little bracket that comes with the pump to work anywhere for me so I did not use it. Quote Link to comment Share on other sites More sharing options...
Heavy Z Posted May 22, 2003 Share Posted May 22, 2003 Yep, that't what I've got, and you can run 'em w/o regs, I do it just as a precaution. Quote Link to comment Share on other sites More sharing options...
alsil Posted July 5, 2003 Share Posted July 5, 2003 I have the 5-7 lb pump. Use a regulator. Also I hope you like the sound of BZZZZZZZZZZZZZZZZZZZZZZZZZ ZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZ ZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZ ZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZ ZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZ ZZZZZZZZZZZZZ Because that's what mine sounds like, even with a decent exhaust note and insulation. Do yourself a favor and put a rubber line between the steel line going up to the frame and the pump, and between the pump and the tank. It will vibrate the whole car. Al Quote Link to comment Share on other sites More sharing options...
Guest zfan Posted July 5, 2003 Share Posted July 5, 2003 Anyone have a video of the two lesbians going at it with a giant vibrator in the back seat . Ok so I'm a old pervert, some things just can't be helped Oh and yeah the Holley blue is noisy I replaced mine or should I say the two lesbians. Mike Quote Link to comment Share on other sites More sharing options...
timh Posted July 15, 2003 Share Posted July 15, 2003 I've had the holley blue, red and the carter in my Z. Each one was carefully isolated with grommets, rubber fuel line, etc. In my experience, the Red was overall the quietest, followed by the Carter, which starts out loud, but gets better after running for a while. Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted July 29, 2003 Share Posted July 29, 2003 DELETE Quote Link to comment Share on other sites More sharing options...
