how to clean up a engine bay? (when swaping in L28ET).......
Guest ON3GO
Guest ON3GO
Hey guys.
me and a few friends were looking at my friends RX7 (1st gen) today. he is doing a V8 swap in it. well i noticed that the guy thats doing the swap made the engine bay soooooo clean, it looked empty kinda.... and i like that. and if you go to the Nicest Z 2 thread you will see a goldish Z with such a clean looking engine bay. So how would i go about doing that to my Z when doing the swap?
thanks
mike
Guest greimann
A clean engine compartment is all about attention details, patience and the willingness to spend some money on the right materials. The main thing that makes an engine compartment messy are the wires and hoses. Careful attention to routing path, straightness, the use of proper clips and coverings, all add up to a neat job. Also maintaining a consistent theme of color and texture are important. Blue wire loom, chrome air cleaner, red hose fittings Aluminum manifold don't play well because nothing matches. Would you have that color scheme on the outside of your car? No, because it looks like a circus clown got sucked up by the fan and scattered about compartment.
Look at the spark plug wires in the following pictures. Why does one look better than the other? Look at other examples of cars you admire. Try to figure out what makes them look they way they do and copy it.
Guest ON3GO
very nice, me like 2nd pic :D.
But how in gods name did they clean up the engine bay on that gold'ish Z in the Nicest Z 2.0 thread? Because there wasint one wire at all.
mike
I did alot on my 240ZT, and now im working on the 73 i just bought.
minimal is always good! your going for a sanitary look, While the white Jspec Z with the workwheels, and the J-spec super Z (the gunmetal grey car) are Extremes of this approach. But with a little work you can still have a nice clean looking Z.
When doing something like this, You must consider if it hurt reliability of your car, Or if it makes it harder to repair in a crunch. so once you figure that out, You can go for it. when you take the engine out, sit on the cross member and look around. you will see many things you can move and remove.
On my 240ZT, I bought a spot weld cutter and removed and bracket that was attached to the frame rail (specifically the old CARB feed and return lines.) i ran new fuel lines coming right up the firewall into a nice regulator, and ran the return right from the reg. This really cleans things up.
If you take off your fender, You will notice that there is a channel that goes underneath them it runs from the firewall, to the front of the fender near the coil mount. On the drivers Side I ran all my FI wiring in the channel, I also put my Ballist resistor in there. This really cleans up as well.
I also mounted my coil on the head where the Fuel pump should go. I ran all the wiring in a polished Alum tube that wraps around the head. (PS heat and vibration will kill coils.) But since i dont drive the car everyday, it doesnt really matter to me.
I also cut apart the sleeving on my wiring harness, And move every relay, or Voltage reg or fusible link into a nice little box in the glove compartment. This also really cleaned up the frame rail. when you remove all those brackets, that leaves you with many holes where things used to be. I took a long while welding up all those little holes.
Now on the 73 im working on now. Im removing ALL the wiring from the engine compartment. How am i doing this? well, Im running the main part of the harness (that goes to the headlights and such) through the fresh air intake system. I drilled a large hole in the passenger side plastic vent thing, and ran all my wiring through that it goes all the way to the front radiator support and out the fresh air intake. (you dont even know its there!) I sealed up the hole i made with a grommet and some sealer, that way the fresh air intake can still function as normal.
On the drivers side im running all the wiring in the channel under the fender.
Now your going to have to splice and add to the harness to make some things work. (drivers side lights) but you can do it. Its oh so easy.
Once again the J-super Zs are extremes. I Made mine so that it wasnt impossible to work on, but still looked clean.
But my next Z will be a super Z, I just need to get my degree first.
laterZ
  • 7 years later...
BRRRRAAAAAAAAAAAAAAAAAAAAAIIINS!!
Seriously though, its not too hard, just time consuming. Label and disconnect your wire harness and other plumbing and test fit over and over to see if it fits and looks good. If it doesn't either deal with it and compromise for something a little less than ideal (but still functional and neat) or pony up and buy the needed parts to make it the way you want it. Just don't get so obsessed with hiding wires and lines that you forget to use proper isolation mounts and such, especially when it comes to SS braided lines and electrical wires. They tend to eat through each other when they touch for a long time, and the end result isn't pretty.
In a helicopter, an insulated electrical wire will "eat" through an adjacent hardline carrying 1500-3000psi of normally non-flammable hydraulic fluid. The end result is a red mist aerosol that will most certainly turn into a gigantic fireball when exposed to a source of ignition (like electrical generators or the wire itself). Think about that when running fuel lines especially.
Edited by Oddmanout84
