auxilary Posted May 27, 2003 Share Posted May 27, 2003 is there an offset in hte crossmember from factory to accomodate for uneven lower control arms in the front? or am I smoking something really good? My front left tire sticks out 1/2" more out than the front right. I haven't measured anything yet, but I recall reading something about the control arms being different lengths? Am I right, or wrong? Quote Link to comment Share on other sites More sharing options...
Mikelly Posted May 27, 2003 Share Posted May 27, 2003 Alex, I've chopped up over 80 control arms in the process of making my adjustable mod to them. I've never noticed a difference in length... There might be in the 510 units, which are almost identical in appearance... But I'm pretty sure all 70-78 control arms are the same, based on what I've seen. Mike Quote Link to comment Share on other sites More sharing options...
johnc Posted May 27, 2003 Share Posted May 27, 2003 Control arms are generally the same length although production tolerances sometimes build up and you'll occaisionally find one arm that's, maybe, .125" longer then another. When you're measuring track width for each side measure from the lower control arm mounting bolt center. Don't measure from any body panels - they are most likely off to some degree. Quote Link to comment Share on other sites More sharing options...
auxilary Posted May 27, 2003 Author Share Posted May 27, 2003 Thanks guys, I just wanted to find out a quick answer before going through the process of jacking up my car. Quote Link to comment Share on other sites More sharing options...
