Guest Anonymous Posted May 29, 2003 Share Posted May 29, 2003 Can somone tell me how hard it is to swap the ford 302 into a 280zx Quote Link to comment Share on other sites More sharing options...
Dp351zcar Posted May 29, 2003 Share Posted May 29, 2003 Easy as a chev but better. Go read the ford section for info. Don Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted May 29, 2003 Share Posted May 29, 2003 thanks don im glad i didnt buy a 350 like i was gonna then.. Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted May 29, 2003 Share Posted May 29, 2003 uhh question i cant find any info on swaping a carburated 302 into a 79 280zx is this possible if so will there be alot of cuting and welding to be done or do the motor mounts match up easily also my current zx is efi and the 302 is carb will this make my project a hurendious event? And one last thing i live in delaware does anyone know of any good z mechanics in my area? Quote Link to comment Share on other sites More sharing options...
Guest tom sixbey Posted August 19, 2003 Share Posted August 19, 2003 hey booda - made any progress? - i'm geting intrested in a 5.0 zx swap myself... lemme know how its going Quote Link to comment Share on other sites More sharing options...
blueovalz Posted August 20, 2003 Share Posted August 20, 2003 I know the hood is a tad shorter on the ZX, but other than that, I see no significant problems that would make this SBF swap any different than in the Z. The rack may become an issue (is the ZX a "rear steer" set-up?). Quote Link to comment Share on other sites More sharing options...
80LS1T Posted August 20, 2003 Share Posted August 20, 2003 The rack may become an issue (is the ZX a "rear steer" set-up?). Yup my 1980 280ZX is a rear steer. I have the power steering with the large gear box and not the newer Rack & Pinion power steering. Guy Quote Link to comment Share on other sites More sharing options...
Mudge Posted August 20, 2003 Share Posted August 20, 2003 The ZX loses something like 3" to the firewall placement. Quote Link to comment Share on other sites More sharing options...
Guest tom sixbey Posted August 20, 2003 Share Posted August 20, 2003 yea - the zx is rear steer and the firewall is moved forward a bit. - I have a '79 with manual rack and pinion steering, and i have yet to see what header clearance issues i'm going to have... - probably wont be too much harder than a 1st generation car... Quote Link to comment Share on other sites More sharing options...
80LS1T Posted August 20, 2003 Share Posted August 20, 2003 yea - the zx is rear steer and the firewall is moved forward a bit. - I have a '79 with manual rack and pinion steering, and i have yet to see what header clearance issues i'm going to have... - probably wont be too much harder than a 1st generation car... So you dont have that big'ol gear box on the drivers side? If no then you have some hope! Guy Quote Link to comment Share on other sites More sharing options...
Guest tom sixbey Posted August 21, 2003 Share Posted August 21, 2003 hehehe - we'll see about that!! hopefully the angle of the steering column wont present too many problems. I believe it cuts towards the rack at a sharper angle in a zx than it does in the earlier cars, so i may not be as well off as i think.. only time will tell Quote Link to comment Share on other sites More sharing options...
