240sx Diff.
gb5422
No, the '89 240sx r200 is not an LSD... Unless you have a Canadian model, or some crap like that. I've heard their 240sx's are pretty tricked out compared to ours. But yes, an r200 will pretty much fit on any Z car. There's a good write-up about this at http://www.geocities.com/zgarage2001/engine.html
Just scroll down untill you find the part about diff.'s...
If you're looking for an LSD, they can be pulled from any '87-'89 300ZX Turbo, and they're a 3.70:1 ratio. You should be lucky enough to find one at a local salvage yard, but make sure it's not a Limited/special edition Z; they came with Viscous LSD's which are no good for a swap(pain in the arse)!
The answer to that is yes and no. Some 240sx have a viscous LSD, but it has a different spline count than the clutch type or open r200. The SX is also a short pinion r200 and is NOT interchangeable with the earlier r200. Also, R200 made before 84 or so are 10mm ring gear bolts and the newer ones are 12mm.
