ecp48 Posted June 1, 2003 Share Posted June 1, 2003 Is there any benefit (increased flow) to using a 280ZX Turbo Air flow Meter on a naturally aspirated 280Z ('78)? Also, does the ZX turbo injectors have a higher flow rate and if so how much? ecp48 Quote Link to comment Share on other sites More sharing options...
Guest livewire23 Posted June 1, 2003 Share Posted June 1, 2003 the turbo injectors are a bit bigger. But if you run turbo injectors with a stock ECU, you will run pretty dirty rich. I have turbo injectors, and I havent gotten my A/F gauge to get out of rich yet... (I think maybe its not wired up right... ) Quote Link to comment Share on other sites More sharing options...
Guest Chase280 Posted June 4, 2003 Share Posted June 4, 2003 There is a lot to be had from a ZXT AFM swap but you have to remember it is a whole system. That AFM will only flow as much as the filter,TB,manifold,head, and the exhaust can flow. Don't expect much out of a TAFM swap if you have not upgraded the other things. Chase 78 280 Quote Link to comment Share on other sites More sharing options...
ecp48 Posted June 4, 2003 Author Share Posted June 4, 2003 Thanks Chase, I have replaced the throttle body (240SX), Air Filter (Hi Flo K&N) and cleaned up the head. Also used a Monza Header with duals. the AFM was a real question in mind, as a restriction. I'll track down a Turbo AFM to complete it. Ed Palmer Quote Link to comment Share on other sites More sharing options...
Guest z1 performance Posted July 5, 2003 Share Posted July 5, 2003 When I first upgraded the injectors on my car from the turbo units, we swapped the 'guts" of the original 79 AFM into the housing" of the Turbo AFM, then simply adjusted spring tension to get things where we wanted. Problem was I still could not dial out enough fuel, so we ended up just fitting the TEC II. Quote Link to comment Share on other sites More sharing options...
lilj Posted June 20, 2004 Share Posted June 20, 2004 the turbo injectors are a bit bigger. But if you run turbo injectors with a stock ECU, you will run pretty dirty rich. I have turbo injectors, and I havent gotten my A/F gauge to get out of rich yet... (I think maybe its not wired up right... ) btw, if its not *too* much more cc wise, you can drill out the MAF and adjust the A/F ratio there Quote Link to comment Share on other sites More sharing options...
zguy95135 Posted July 24, 2004 Share Posted July 24, 2004 Could you get a NA 280Z to run good if you swapped in turbo injectors and the ECU, or would you need the turbo AFM too? Quote Link to comment Share on other sites More sharing options...
Afshin Posted July 24, 2004 Share Posted July 24, 2004 the timing profile of the turbo ecu would probably make the NA car run slower (retards timing as engine load increases to account for increase boost pressure). Would not recommend changing the ecu. Quote Link to comment Share on other sites More sharing options...
