Anyone wired an HKS EGT meter?
SleeperZ
I got one cheap off eBay, maybe there was a reason it was cheap....
Anyway, it has connectors and wiring off the back, but I can't find any information on wiring it. It has 2 connectors, a 3 pin at the bottom, with 2 wires (red and white). I am somewhat certain this is for the face illumination, and I can test that. The other connector has 4 pins, red, black, orange and yellow, and I can guess two are for the power and two are for the EGT probe...
Does anyone know for sure? I found a manual for a Greddy on the web with similar features (memory recall of the peak), but that unit had a sender box. I am hoping this thing doesn't need it, or I've wasted $30.
Hey I got a greddy, and it doesn't have a sender box. It has two plugs in the back, one for the probe, and one with 4 wires for illumination and such.
If you want, I will scope it out and let you know when I get home. If I forget (its easy for me to do), shoot me an email. Its not hooked up yet, although the probe is run, and all that.
I am lazy. :lol:
The one I've got is somewhat different - it has two buttons labeled Reset and Select, an LED in the display, and it's a 52mm gauge. It starts at 500C and goes up to 1150C. The model number is P6ET. But anything could be of help - if you have a manual for the one you have, maybe it's similar in it's wiring scheme..?
