dat240zg Posted June 10, 2003 Share Posted June 10, 2003 Just curious; I've heard of some people running a return line when swapping the L28t into a series1 (more specifically, a 240) but I haven't been able to get the definitive word on whether it's needed. Also, I'm using the '75 tank and am wondering if the stock fuel line will cut it as far as flow is concerned. Anyone able to help? Thanks. Bryan Dat240zg Quote Link to comment Share on other sites More sharing options...
SleeperZ Posted June 10, 2003 Share Posted June 10, 2003 The return line is absolutely needed. The '75 tank will support the turbo motor as far as you need to go. It has 7/16" feed to the pump, 5/16" supply and 5/16" return - that will support 400hp at reasonable pressures. Just remember to keep the fuel above 1/4 tank if you are flogging the car - I was running below that at the track, and coming out of a hard left turn, the engine would momentarily stumble. As soon as I filled up, the problem went away. Quote Link to comment Share on other sites More sharing options...
Lockjaw Posted June 10, 2003 Share Posted June 10, 2003 I agree. In my 240, the stock efi pump would work with the stock return line, but once we went to walbro pumps, man they were way to small. I ran a .5 inch copper line for fuel and used the fuel line as the return, not that it was necessary. If you want to have fun and go fast, time to upgrade. Quote Link to comment Share on other sites More sharing options...
