PISTON QUESTION
This probably isn't the correct way, and Grumpy et al will have a coronary, but I have always just used a vise with a piece of tube (with an ID larger than the OD of the pin)and a socket or something similar to push it out. Sometimes I heat the piston a bit, sometimes it's not necessary.
Otherwise take then to a machine shop.
Tim
utvolman99
is correct if you don,t have a hydrolic press set up to do that job your way better off getting a machine shop to do the job for you,and not screwing up the pistons or piston pins or the connecting rods( thats one of the problems you run into when you use pistons with pressed pins, and its one of the problems you can avoid by building engines with full floating pistons
