What a 1,000 horsepower supercar should look like
Heavy Z
Guest Your Car is Slow
When you use 4 of them..they dont need to be all that large :)
That thing must be a tuners nightmare...not that anyone who buys it would ever turn a wrench on it :)
This is the ultimate road lord. Bugati Veyron...four-turbo V16...987 horses and 922 torque in stock trim...0-185 in 14 seconds, 250 mph top speed. Awesome.
.......... :shock::shock::shock::shock::shock:
What would it do in the 1/4 mile? :twisted:
Is that a real car or just a concept car?
Guy
Probably low 10s at some insane mph..(certainly traction limited more than anything on street tires).
Its real...cost in the 7figures though :shock:
Let's not forget that the base price of that monster is around a million dollars a pop.
All that for a car that's as ugly as an old shoe. The least they could have done is make it pretty to look at. Oh well - when you're the three hundred pound gorilla on the block, I don't guess you need to look nice.
Dudes, please give it up for Bugatti! :hail::rockon: How about 2 huge turbo upgrades? :lol:
Technical Specifications
Engine
Layout W-engine, two V8 cylinder banks at a 90-degree included angle
Installed position mid-engine, longitudinally ahead of the rear axle
Number of cylinders 16
Displacement 7,993 cc
Bore x stroke 86.0 mm x 86.0 mm
Valves 64 (4 per cylinder)
Power output 736 kW (1001 bhp) at 6,000 rpm
Torque 1,250 Nm from 2,200 - 5,500 rpm
Compression ratio 9.0 : 1
Mean effective pressure at max. power output 18.4 bar
Mean effective pressure at max. torque 19.7 bar
Mean piston speed 17.2 m/s
Forced aspiration 4 turbochargers
Driveline / wheels
Gearbox 7-speed sequential-shift
Drive to wheels permanent all-wheel drive
Front wheels 235 x 520 A. alloy
Rear wheels 325 x 540 A. alloy
Front tires 245-690 R 520 A
Rear tires 335-710 R 540 A
Body
Construction principle load-bearing, aluminum
Length 4,466 mm
Width 1,998 mm
Height 1,206 mm
Wheelbase 2,700 mm
Track, front 1,723 mm
Track, rear 1,632 mm
Performance
Top speed 406 km/h
Acceleration 0 - 300 km/h under 14.0 seconds
Guest Ziggy Vulcan
Sweet. It just seems like they could have done a little better in the power department with a quad-turbo V16. Cadillac made a car with a V16 that was NA with the same power figures. Hell, you could probobly get a twin-turbo small block to pull that if you knew what you were doing. BUT, I think that thing could be a huge beast with some bigger turbos on it.
I dont know about the looks though. Fix the front and it should be pretty cool. It is definately innovative...
From what I understand, you couldn't just buy one. Ive heard that when someone puts in a request for a Bugatti, they have to wait for months. And then, when the owners of the company finally contact them, they invite them to dinner where they decide if they want to sell that person their car.
I can't confirm this, ofcourse...
By the way, I believe Volkswagon makes that engine.
