Georgia Flash Posted June 19, 2003 Share Posted June 19, 2003 Holy crap am I ever pleased with the way the Modern Motorsports rear disk conversion is going so far! I went to the local salvage yard and plucked me two 240SX calipers to go with my kit provided by Ross C. http://www.imagestation.com/picture/sraid65/pf27e4668c50e8ac3f29214d068a05330/fbe49af0.jpg I am going to try and post a few pics of what I have done so far, I hope the links work for you guys. http://www.imagestation.com/picture/sraid65/p4aa5ec9527abf12fce56017edab46af9/fbe49af3.jpg I will work on them a little more tomorrow when I get the overhaul kit for the calipers. The calipers bolt right up to the custom bracket just like they came that way from Nissan! Great kit Ross!!!! Quote Link to comment Share on other sites More sharing options...
Guest Your Car is Slow Posted June 19, 2003 Share Posted June 19, 2003 This is next on my list of "To do" stuff! Quote Link to comment Share on other sites More sharing options...
Georgia Flash Posted June 19, 2003 Author Share Posted June 19, 2003 Man I am telling you so far so good! I expected to have to do a little fabbing here and there to get the bolts to line up and so forth but it is a quality package! Everything fits like a glove! If you are going to do this go ahead and get the overhaul kit for the 240 calipers before you order the kit from Ross. That way when the kit comes in you can go ahead a get the used calipers from a salvage yard clean and paint and slap em on. The most difficult thing so far was removing the dust or backing plate for the old drum brakes. pita!! Once they were gone the rest has been easy. Quote Link to comment Share on other sites More sharing options...
Georgia Flash Posted June 20, 2003 Author Share Posted June 20, 2003 Ok I finished the passenger side of my brake upgrade including hooking up the emergency cable and guess what I found? It seems that with the new brake hardware my old crusty wheels now will not fit. I had been using an old set of Nissan 15in 240SX factory rims but it now scrubs the caliper. What rim size and off set do I need to finish out my sweet upgrade? Keep in mind I will want the same rims for the front which are stock. Come on guys I know someone else has done the swap and knows what advise to give. I also emailed Ross C. about the question. It is no big deal I had planned on getting new wheels anyway, just not right now. Quote Link to comment Share on other sites More sharing options...
Drax240z Posted June 20, 2003 Share Posted June 20, 2003 Is it close enough that you can do a bit of grinding on the caliper to get wheel clearance? At least it would let you drive the car a bit before shelling out more $$$ for wheels. Quote Link to comment Share on other sites More sharing options...
Guest ON3GO Posted June 20, 2003 Share Posted June 20, 2003 ok ok hold up.. u have stock 240sx calipers and rotors and 15in rims dont fit? is that right or am i wrong. im about to buy 16in panasport C8R's and i have those rear brakes u have and 12in rotors up front with big ass wilwood calipers! Quote Link to comment Share on other sites More sharing options...
fl327 Posted June 20, 2003 Share Posted June 20, 2003 they wont fit with nissan factorywheels should fit behind enkei or other 0 offset 15 x7 rim Quote Link to comment Share on other sites More sharing options...
Guest ON3GO Posted June 20, 2003 Share Posted June 20, 2003 cuz im gonna be running -7 up front and -8 out back (or even more?!?) have no clue about backspaceing and etc.... i dont even no how to get that. lol Quote Link to comment Share on other sites More sharing options...
Georgia Flash Posted June 20, 2003 Author Share Posted June 20, 2003 Yes I have the stock 240SX calipers but remember the disks are from a 300ZX. So I would imagine that the stock 240SX calipers are in a little bit different place than would be found on a stock 240SX. Did that make any sense? Anyhow, I'm sure that Ross will be able to tell me what to do, I just thought that some of you folks had done this set up and had a little experience in getting the right wheel size. I think I may be going the Panasport rout myself. Quote Link to comment Share on other sites More sharing options...
Georgia Flash Posted June 20, 2003 Author Share Posted June 20, 2003 More pics of the swap http://www.imagestation.com/picture/sraid66/p458bcb8b0a6879ee588a653e3a45ce52/fbe2162f.jpg http://www.imagestation.com/picture/sraid66/p39fb28495e11562188f3b6ad8c2975b0/fbe21631.jpg Quote Link to comment Share on other sites More sharing options...
Guest 240hybrid Posted June 20, 2003 Share Posted June 20, 2003 what year 240sx calipers are those? Quote Link to comment Share on other sites More sharing options...
Georgia Flash Posted June 21, 2003 Author Share Posted June 21, 2003 I think they came off of a 91 Quote Link to comment Share on other sites More sharing options...
Georgia Flash Posted June 21, 2003 Author Share Posted June 21, 2003 Does anybody know what offset I need with these new brakes? Quote Link to comment Share on other sites More sharing options...
j260z Posted June 21, 2003 Share Posted June 21, 2003 i don't think the offset changes because the disc should take up the same amout of space as the drum did. Quote Link to comment Share on other sites More sharing options...
DavyZ Posted June 22, 2003 Share Posted June 22, 2003 Does anybody know what offset I need with these new brakes? Better give Ross a call just to make sure! Your setup looks fantastic! Did you use special caliper paint on the calipers or just regular enamel? Lookin' good! Davy Quote Link to comment Share on other sites More sharing options...
Georgia Flash Posted June 23, 2003 Author Share Posted June 23, 2003 Davy, I used high temp engine enamel (ford blue) I got an email from Ross and he suggested 16x7 inch rims with 225/50/16's tires. Quote Link to comment Share on other sites More sharing options...
BARACU Posted June 23, 2003 Share Posted June 23, 2003 I just completed my 75Z with Ross' front and rear conversion. I have Compomotive 3 pc wheels in 16x7 with 0 offset and 225-50-16 Hankook tires. Everything is a perfect fit with no rubbing and look great. I have Tokico shocks and suspension technique springs which lowered the car a bit, but no problems. You may have to "remove" the stock L bracket for the stock brake lines, that's welded to the frame. Mine were hitting the the e-brake bracket. Good luck on your project Quote Link to comment Share on other sites More sharing options...
Georgia Flash Posted June 23, 2003 Author Share Posted June 23, 2003 Are you talking about the L bracket that you can see in my picture? Or the one down low near the stub axel? I removed the one down low it was bolted on. The one in the pic doesn't come close to the ebarake function unless I have done something wrong. Quote Link to comment Share on other sites More sharing options...
BARACU Posted June 23, 2003 Share Posted June 23, 2003 I'm talking about the one in the pic. Once I had the car on the road, I found it to be hitting part of the e-brake. In fact, it had bent the bracket. A few minutes with the Sawzall, solved the problem.Just something for you to keep in mind. Quote Link to comment Share on other sites More sharing options...
Georgia Flash Posted June 23, 2003 Author Share Posted June 23, 2003 Gotcha, I will cut them off before I let the car down off the jack stands. I oredered some Panasport 16x7 wheels and Yokahama 225/50's today so I will get rid of them little rascals before I put the new rubber on. Thanks Quote Link to comment Share on other sites More sharing options...
