sds'ers
Guest dustyz
I am using the EM-6E system, on a mostly stock L28 turbo. The departures from stock right now are a slightly bumped up compression ratio (7.5:1), a 60mm TB, and an NPR intercooler with associated piping.
hp: Couldn't tell you, though I drove the car for the first time yesterday. :D
Guest dustyz
yeah stony but you have a rb motor
i need to know how to work coil packs on a l6 motor or if it even posiable(sp)
gurrr need to get sds soon so i can get my car running :cry::cry:
well thanks for the replys what type of injectors are you big hp numbers people running
Guest dustyz
Yeah but is there any little snag in installing the sds, m6f and coil packs in to a datsun.
The only person i know that has the coil packs on an l6 in the guy tht also has 2 turbos so he can do most things that would snag the hell out of me :D
I've been running an Em3-6F with coilpacks for 3 years now on my L28et - no problems and I'm very happy with the system. The is another guy in my local club running the same system that hangs here - his name is Nigel.
Cheers - Doug
It is no more work to run the E/MSD system or coil packs. You have to fab a crank sensor bracket for both systems and mount magnets to the pulley wich isn't hard. I guess you have to run different plug ends on the coill packs, no biggy though.
Guest dustyz
I am just saying that he could do most things i could not,he made his own turbo headers, so he can weld like a mo fo and do all sorts of crazy things
that i would not be able to do :D
I threw away the dizzy, capped off the hole in the front cover and cut off the drive shaft just above the bearing surface above the drive gear. That is where the shaft diameter gets smaller above the drive gear. Then the end of the shaft that used to run the dizzy isn't in there unsupported on the upper end. Check your Haynes manual and get a good idea of how the oil pump/dizzy shaft works in there
Happy conversions - Doug
