doing my suspension... what else would be needed..tools etc.
Guest ON3GO
Guest ON3GO
hey guys,
im now taking apart my Z to install the following parts.
Modern Motorsports coil-overs.
Tokico Illumina struts.
Energy Suspension bushings.
silvia/240sx rear brakes.
Modern Motorsports rear brake mounts.
Wilwood calipers and rotors up front.
280zx turbo clutch master cyld, release bearing, slave cyld.
anybody know what else i should buy that i should replace or that would be worth doing while im down there?
Ross said he was sending me bump stops but i havent heard back from him.
im also looking for the Stainless steel brake lines for my brake upgrade but i cant find anything at all.
also does anybody have ideas that make putting these parts in easier and etc.
any tools i need to put these parts in and also take the parts im replaceing off?
lol really any info would be great.
Thanks guys
You are going to need a pickle fork to seperate the ball joints, spring compressors, spindle pin puller and of course air tools make the job much easier. I just pulled my suspension apart last weekend and it can be quite a job without the correct tools. A vice on a work bench is always a big help as well.
Guest ON3GO
oh im sorry i must have not read it right or something.. my bad.
will they be shorten already like u said is good tohave, or will i need to do it?
Just send me a email or PM on how much it is and etc.
thanks man.
I do have a question.
with ur rear brake brackets i bought. can i use the 240sx stock rotors also? or no? cuz if not ill have to look for upgraded vented rear rotors.
thanks
Mike
  Quote
I did my first dozen or more struts with spring compressors to disassemble prior to coilovers etc....then a bud I trust said he's just undone the tops on Z struts with minimal 'spring' on release......I've since done at least a dozen or more struts just using my heavy impact gun on the end (ie. no spring compressors), with strut lying flat on the ground and a small sheet of plywood laying on top of the rest of the strut just for a precautionary shield with one of my feet on top of the board..... And I generally place a 4x6 chunk behind my impact to minimize the kickback...strut top jumps off and rolls a foot or two at most with NOTHING dangerous happening. This on 240Z/280Z and 280ZX struts. I'm sure some other vehicle models have far higher spring preload stresses locked in but so far the used Z units have been easily taken apart without compressors, a very handy tip if it's something you do reasonably often :D Goes from a 20 minute job/pair with compressors and air to a 5 minute job without compressors if that.
YMMV
You dont even need to go through that much trouble releasing a spring from a strut assembly. IF the strut you are replacing is shot, you can take a vice grip, lock it down on the shaft, place the assembly on the ground so the vice grip cant rotate, throw a blanket over the assembly, straddle the assembly, and then release the nut. Nothing flys anywhere and everything stays under the blanket.
I have released them before without a spring compressor but it sounds like this is his first one and I was just trying to be safe. Good tips on the plywood and blanket / vice grip methods though.
