Need help with clutch master cylinder
BRAD D
My car is running, and the clutch is not fully engaging. I am using a RB25 clutch slave, and an OS twin plate clutch hooked up to th e stock clutch master cylinder.
What master cylinder can i swap in to give my clutch slave more travel?
My slave cylinder says 3/4 on the side of it...
Brad,
Go on over to skylinesdownunder.com and post a question asking what size clutch master cylinder a 95 RB25 has? (or whatever year your motor or tranny was - 98?).
I'll need to know as well.
-Bob
Another option is a larger diameter clutch master cylinder....Don't know what models have a larger diameter though. You might consider posting your entire setup on skylinesdownunder and seeing if anyone else is running an OS twin plate on their RB25.
-Bob
Guest zline
yeah, im 90% sure you can - tilton parts are rebuildable so tinkering isnt a problem at all just make sure you dont damage the circlip!!
