RB26240Z Posted July 15, 2003 Share Posted July 15, 2003 Can someone shed some light as to what sensors are used when the aftermarket ecu such as SDS is used, e.g, map sensor, 02 sensor,etc.. thanks. Quote Link to comment Share on other sites More sharing options...
stony Posted July 15, 2003 Share Posted July 15, 2003 nothing on sds. you use all there sensors. other systems you can use the stock stuff but not real familiar with other systems Quote Link to comment Share on other sites More sharing options...
BRAD D Posted July 15, 2003 Share Posted July 15, 2003 the SDS will work with the stock RB26: TPS, air temp, water temp, knock. you will need a MAP from SDS because the RB stock works on MAS Quote Link to comment Share on other sites More sharing options...
RB26240Z Posted July 15, 2003 Author Share Posted July 15, 2003 Thanks Stony & Brad Quote Link to comment Share on other sites More sharing options...
stony Posted July 15, 2003 Share Posted July 15, 2003 i used sds's stuff to ensure i had all good sensors to start tuning.... the stock o2 sensors were trash so i played it safe and replaced all new sensors with what SDS guys recomended Quote Link to comment Share on other sites More sharing options...
