T56 Flywheel - 400 Crank Compatibility???
Guys, I need help locating a T56 Flywheel that will be internaly balanced & have the 400 Crank bolt pattern. My current crank only allows me to have my setup externally balanced. Any help would be appreciated.
I think Hays makes a steel flywheel for the T56 that will work. Maybe a call to Summit you can find out for sure. Mcleod makes some changeover type products as well, and PAW is probably their biggest vendor. Isn't the 400 bolt pattern the same as the two piece other small blocks, just with a locating dowel?
