JohnG. I can't PM you....About the oil pan issues...
John, Send me an e-mail about the canton pan... Just an FYI, I can't seem to get anyone to balance my engine so I haven't been able to do anything with the pan yet, so I can't speak to its usefullness as of yet...
Mike :eek:
OK. Thanks anyhow Mike and good luck getting the rotating assembly balanced. That's important, for sure.
Maybe I'll go ahead with the Canton pan. Already poked a hole thru my 7-qt. Moroso on a tire dealer's rack and had to have it welded up ($100). Scared of speedbumps, humps, manholes, driveways, etc. and gotta do something.
--JohnG
Yep, Mike C is right...the May/June Summit catalog has a Hamburger's pan that is only 7" deep at the sump. Ed Hamburger started his oil pan outfit in the Cleveland area a number of years ago.
But this pan is still 7-qt. capacity, so in reducing depth, the width had to increase substantially, which probably means interference issues with the collectors on my block-huggers. It's worth a phone call, anyhow.
Thanks, Mike.
