240Z Turbo Posted August 29, 2003 Share Posted August 29, 2003 I had the company Advanced Thermal Protection build me a custom intake manifold heat blanket. Check out their website, it is amazing the work they do. http://www.atpwrap.com These guys are awesome and the turnaround time was 3days. The heat on the intake manifold kills power on our turbo cars as the exhaust manifold sits directly below the intake. I will have the final pics later today to post. Here are the ones I currently have. The shields are inconel that cover the runners and fuel rail. Quote Link to comment Share on other sites More sharing options...
clint78z Posted August 29, 2003 Share Posted August 29, 2003 DANGER Wil Robinson Danger Very Robbie the Robot, sorry couldn't resist. It looks funky. I am going to dig around our shop, I have acess to several different types of insualtion. We get this ceramic concrete stuff takes direct +1500F flame. Lot's of that type of insulation in the boilers I design. It will really help on the turbo cars. Quote Link to comment Share on other sites More sharing options...
Guest cbrunberg Posted August 29, 2003 Share Posted August 29, 2003 In one of my other lives I was a horse shoer. I used to make my own forges and used a product called Kaowool to line the box. It took a direct flame about 2000 degs and left the outside of the sheet metal box cool enough to touch. You can find it at ceramic supply stores. It's not as pretty as you inconnel sheilds but may work with them between the sheild and your runners. Carl Quote Link to comment Share on other sites More sharing options...
240Z Turbo Posted August 29, 2003 Author Share Posted August 29, 2003 the inconel is actually a .004" sheet that is stamped into a waffle pattern. A layer of high temp fiber glass is then applied and another layer of .004" inconel sheet. Basically, you have a high temp fiber glass sandwhiched between two layers of .004" stamped inconel sheet. This creates a 3000F heat barrier. It is not just a metal shield. Quote Link to comment Share on other sites More sharing options...
Guest cbrunberg Posted August 29, 2003 Share Posted August 29, 2003 Wow that's cool! And looks great. Thanks for sharing it. Quote Link to comment Share on other sites More sharing options...
240Z Turbo Posted August 29, 2003 Author Share Posted August 29, 2003 Quote Link to comment Share on other sites More sharing options...
240Z Turbo Posted August 29, 2003 Author Share Posted August 29, 2003 whoops Quote Link to comment Share on other sites More sharing options...
jmead Posted August 30, 2003 Share Posted August 30, 2003 that is pretty sweet, very professional, and looks like it will be effective. Have you dynoed the car recently so you can compare power increases from the cooler charge? Or a temp sensor in the intake at least, so there is some idea of actual gains? Quote Link to comment Share on other sites More sharing options...
yo2001 Posted August 30, 2003 Share Posted August 30, 2003 Nice, I got the alumium coated fiber blankets on all my heatshields. I do have a question, I thought most of the heat that gets to the intake transfers from the head? Quote Link to comment Share on other sites More sharing options...
240Z Turbo Posted August 30, 2003 Author Share Posted August 30, 2003 That is my next project, a phenolic spacer between the intake and head. Quote Link to comment Share on other sites More sharing options...
yo2001 Posted August 30, 2003 Share Posted August 30, 2003 I'll be all over that. Let me know if you make one. I'll buy one from you. Quote Link to comment Share on other sites More sharing options...
BayAreaZT Posted August 30, 2003 Share Posted August 30, 2003 That is Awesome!!! How much did the intake blanket set you back? G10 spacer between the intake and head will be sweet with all that blanketing. Quote Link to comment Share on other sites More sharing options...
Cody 82 ZXT Posted August 30, 2003 Share Posted August 30, 2003 That is my next project, a phenolic spacer between the intake and head. Whats this going to be made out of? How will you make it since both the intake and the exhaust use the same bolts for clamping force? Quote Link to comment Share on other sites More sharing options...
