Guest bastaad525 Posted September 6, 2003 Share Posted September 6, 2003 I need to find another dyno.... Should have the head back on and the car running today but dammit I gotta be at work soon too so I may not get it done and even if I do probably will just have my g/f drive me. PLUS I forgot to go drop the battery and get it charged Quote Link to comment Share on other sites More sharing options...
scottyMIz Posted September 7, 2003 Share Posted September 7, 2003 congrats yo now i just have to get mine on the dyno some day Hey you wouldn't have another turbo piston laying around would you? ummmm i broke another Quote Link to comment Share on other sites More sharing options...
yo2001 Posted September 7, 2003 Author Share Posted September 7, 2003 I think I throw the rest of the set away. but I'll see what I can come up with. Thanks guys Quote Link to comment Share on other sites More sharing options...
SleeperZ Posted September 7, 2003 Share Posted September 7, 2003 That's looking much better Yo! Your first results I thought were too low for the boost level you were running, especially with the bigger turbo. That's about what I was putting down with stock injectors, I think. Quote Link to comment Share on other sites More sharing options...
Guest miloz31 Posted September 10, 2003 Share Posted September 10, 2003 We gave the car 2-3 deg timing and turn the boost a turn (now it holds solid 12psi' date=' after spiking 14psi ) We also turn the fuel pressure up to 44psi. The timing helped alot, it alone gave me 20ft/lb. I'm pretty inpressed with Z31 setup. I mean I dynoed those number with stock 265cc injectors@44psi. A/F was 11.8-12:1. Pretty consistant too.[/quote'] I heard it is very difficult to install the HKS AFR on a Z31 ECU. How much did you pay for your HKS AFR by the way? Later Quote Link to comment Share on other sites More sharing options...
yo2001 Posted September 10, 2003 Author Share Posted September 10, 2003 $230 for the unit and $63 for the rpm signal converter (which I had to pay $15 special order fee) Quote Link to comment Share on other sites More sharing options...
Guest miloz31 Posted September 10, 2003 Share Posted September 10, 2003 $230 for the unit and $63 for the rpm signal converter (which I had to pay $15 special order fee) So, how was the install and is the tuneability worth it? Quote Link to comment Share on other sites More sharing options...
yo2001 Posted September 10, 2003 Author Share Posted September 10, 2003 Installation is easy. But I haven't used it yet because I couldn't get it to work properly when I was on the dyno. I think it was because I was by passing the rpm converter. If you are going with bigger injectors, I say it's well worth it but as you can see from my dyno, stock ECU can get you pretty good power if tuned. Quote Link to comment Share on other sites More sharing options...
Guest miloz31 Posted September 10, 2003 Share Posted September 10, 2003 Installation is easy. But I haven't used it yet because I couldn't get it to work properly when I was on the dyno. I think it was because I was by passing the rpm converter. If you are going with bigger injectors' date=' I say it's well worth it but as you can see from my dyno, stock ECU can get you pretty good power if tuned.[/quote'] I already have a JWT 500 SETUP w/ 420cc injectors but want to tune more hp our of it. I thought you had it working properly? Quote Link to comment Share on other sites More sharing options...
yo2001 Posted September 11, 2003 Author Share Posted September 11, 2003 When I was on dyno, I had a problem with rpm converter so it was messing up when the MAF pass 5V reading. I think I got it working now but I don't need it since I've already dynoed without it. Quote Link to comment Share on other sites More sharing options...
Guest miloz31 Posted September 11, 2003 Share Posted September 11, 2003 When I was on dyno, I had a problem with rpm converter so it was messing up when the MAF pass 5V reading. I think I got it working now but I don't need it since I've already dynoed without it. Kinda confused? What do you mean," MAF pass 5v reading"? Was the Z31 ECU confused when you installed the rpm signal converter? By the way since you dyno tune your Z w/o the rpm signal converter. Why did you even purchase the rpm signal converter? Quote Link to comment Share on other sites More sharing options...
