Best Coilover Choice
Guest thinkmonkey
  • Replies 43
My rates can't be compared to anyone elses... that sounds a little funny. I have digressive pistons in the Penskes on my 240Z and none of the shocks mentioned so far offer that type of rebound curve.
And, at the moment, I don't even know what the digressive rates are because Erik lost the printouts from the shock dyno. Here's the current settings if anyone wants to get more confused:
Front
Rebound - 4 off full hard
High Speed Compression - 8 off full soft
Low Speed Compression - 8 off full hard
Pressure - 225 psi
Rear
Rebound - 2 off full hard
High Speed Compression - 6 off full soft
Pressure - 175 psi
These setting will change at the next event (they always do!)
Mat, your link was very useful - thanks.
I've ended up with very similar SPRING rates to you ( mine are 180lb front and 200lb rear 10 Inch long 2.25 diameter) - mainly because I sometimes have to drive the car on torn-up urban roads here in London. Some of our country roads have some pretty nasty 'surprises' on them too.
I've come down quite a long way on spring rate over the last year ( in three increments ) and ended up with these. I had the dampers re-valved by Bilstein's UK operation each time. Now I'm at 180 Bump-110 Rebound for the fronts, and 210 Bump-120 Rebound rear.
I have Rose ( Heim ) jointed and adjustable TCA's and Tension Rods. Also have Uniballs in the ( solid ) top insulators / mounts that you can see in the photos of my set-up posted previously. I think these are not ideal for my needs and might try to find a way to go back to a rubber-bushed set-up in the near future. Interestingly, this very point was raised several times by some fine minds in your excellent thread.
All the best,
Alan T.
