Guest matt24680Z Posted October 1, 2003 Share Posted October 1, 2003 Thius gives you an idea about how pissed I am about the Z I bought. It is a '71 240 that is supposed to have an engin that will turn over. But it is totaly seized. All I want to know is how to fix it. Quote Link to comment Share on other sites More sharing options...
JMortensen Posted October 1, 2003 Share Posted October 1, 2003 I think a little more info is necessary. What engine? What do you mean seized? Do you mean the starter won't turn it, or you can't turn it with a breaker bar on the crank pulley bolt? Have you taken the valve cover off? Any broken valves or springs? Jon Quote Link to comment Share on other sites More sharing options...
Guest rick458 Posted October 1, 2003 Share Posted October 1, 2003 A good place to start is to take the plugs out and put 2-3 ounces of Marvel Mystery Oil in the cylinders through the plug holes and let them soak overnight then try and bump it in the morning (dont have a nice car in the garage when you bump it). Quote Link to comment Share on other sites More sharing options...
Guest matt24680Z Posted October 23, 2003 Share Posted October 23, 2003 the engin is the 2.4L straight 6. it is seized to the point that i was not able to turn it over with a breaker on the crank pulley .I have taken most of the motor appart and I have pulled it from the car. There are no broken engin parts. Some of the cylenders were filled completly with corosin or som sort of poder that was not supposaed to be there. Quote Link to comment Share on other sites More sharing options...
JMortensen Posted October 23, 2003 Share Posted October 23, 2003 Sounds like it's time to get a 2.8 bottom end and slap that E88(?) head on it. Jon Quote Link to comment Share on other sites More sharing options...
Tim240z Posted October 23, 2003 Share Posted October 23, 2003 I have a 2.4 long block...it's yours if you want to pay for shipping. Tim Quote Link to comment Share on other sites More sharing options...
Guest matt24680Z Posted October 24, 2003 Share Posted October 24, 2003 thanks but a friend said that if I need a block he has one. but if that falls through I will get in touch. Quote Link to comment Share on other sites More sharing options...
