Turbo Meister Posted November 18, 2004 Author Share Posted November 18, 2004 That's my total goal' date=' a 9 second street car.[/quote'] It will not be easy unless you turbo, supercharge or use nitrous. And then the entire drivetrain needs to be upgraded too. But as you can see, it can be done. How do you intend to achieve this???? Hanns Quote Link to comment Share on other sites More sharing options...
Cable Posted November 18, 2004 Share Posted November 18, 2004 Honestly, I am not sure. I just want to go as fast as I can with the stock IRS. If that ends up being low 11's or maybe even high 10's, I'll be happy. I was intending on building a stout short block 383 stroker combo, decent heads, then hitting it with a large two stage nitrous setup. But I do like the idea of just having the power on tap all the time. So a single or twin turbo setup comes to mind. But I didn't want the hassle or cost of an EFI setup either. So, I starting searching and found that you have a proven setup while still using a carb, and no intercooler to boot. So, at this time I am at a toss up. I have already began searching ebay and such for a pair of turbos, but in all honestly I don't have a clue on what size to buy if I am running a twin setup OR what size for a single turbo setup. Or even which would be better in a 280z w/a Chevy 383 stroker. Some people I know have suggested a pair of T-3/T-4 for a twin turbo setup or a T-76 or bigger for a single turbo setup. Any thoughts on this? I already have a decent, stock headed, hyd cam, 383 stroker under the hood now. It doesn't have any problems dealing with the local Camaro's, Corvette's, EVO/STi's, or any other local import. However, the motor is mild and was really only placed in the car in order to get some suspension issues taken care of, plus the car will be receiving a 10 point cage in the near future. So now I am collecting and building the next 383..... Since you have already have taken care of some of the fittment issues, I think I am going to "bite" on some of your ideas. Prime example would be your exhaust manifolds. I am highly interested in seeing pictures of the rest of the exhaust piping and the routing. What size are your turbo's? Any suggestions you have as to turbo size, etc, or any other topic, please mention it. I am wide open to your ideas and thoughts. Thank you for your time. Quote Link to comment Share on other sites More sharing options...
Turbo Meister Posted November 19, 2004 Author Share Posted November 19, 2004 What size are your turbo's? They are 14 year old Rajays' date=' 370 E 80's, that I'm borrowing from a friend. [b']I'm using twins because I like the way they balance the look of the engine department.[/b] But if I had to buy the turbos, I would have used a large single to save money and to allow a much easier installation. Then a front mount intercooler could also have been mounted. You would not like the looks of my exhaust system. In order to avoid carving up the inner fender sheetmetal, the dual 3" exhaust runs below the front crossmember after the down-pipes. Then the exhaust runs over the rear differential, through large Flowmaster mufflers and out the back. The exhaust is oval pipe which gives some clearance but I always scrape over speed bumps. Driveways and dips in the road are not generally a problem. Even if you buy used parts, turbos,wastegates, blowoff valves, downpipes, timing retard devices, big fuel pumps and fuel regulators will all add up. Before adding the turbos the Z ran 11.15 @ 123 mph, regularly. Keep that in mind while saving money for the turbo system. Hanns Quote Link to comment Share on other sites More sharing options...
Owen Posted November 19, 2004 Share Posted November 19, 2004 Hey Hanns, Been a while, hope you're doing well! If you were to do it all over again, I'd still tell you to go twin, it's just so sexy you know? You can probably still use intercoolers if you can rotate your turbos, check out the pix of the Z with the TT Q45 engine. But...you're not trying to go any faster are you??? Owen Quote Link to comment Share on other sites More sharing options...
Turbo Meister Posted November 20, 2004 Author Share Posted November 20, 2004 But...you're not trying to go any faster are you???Owen Owen, Nice to hear from you. If I ever get my timing and fuel delivery figured out, I will go faster. But that means I will only get kicked off the dragstrip more often because I don't have a certified cage and competition license. How is your awesome Z doing? Hanns Quote Link to comment Share on other sites More sharing options...
Owen Posted November 21, 2004 Share Posted November 21, 2004 I wish I could brag like you! My Z suffered some electrical problems, wire came loose but it's all better now! We'll have to meet up some time, Owen Quote Link to comment Share on other sites More sharing options...
Guest bastaad525 Posted November 29, 2004 Share Posted November 29, 2004 Hey can someone relink to the pics of Turbo Meister's car? They are all red x's now. Or just post a link to a webpage if there is one? I would love to get another look at the setup, and have a few friends who are very interested as well. Quote Link to comment Share on other sites More sharing options...
Turbo Meister Posted November 29, 2004 Author Share Posted November 29, 2004 Hey can someone relink to the pics of Turbo Meister's car? They are all red x's now. 525, The photos were taken by Hybrid240z. He might be able to repost them, if he still has them. I also have several pics in my photo gallery and would be willing to take additional specific photos if anyone is interested. Hanns Quote Link to comment Share on other sites More sharing options...
Guest bastaad525 Posted November 30, 2004 Share Posted November 30, 2004 your gallery here at hybrid z or you have them hosted somewhere else? EDIT: n/m I found it... my god I'm drooling all over the place again Quote Link to comment Share on other sites More sharing options...
Psykovertible Posted January 25, 2005 Share Posted January 25, 2005 I too would really like to see the pics from before. Almost feel cheated. I would sacrifice much to acomplish a setup like that but my wallet says single turbo at best. If you have a cd burner I would send you a prepaid padded envelope and disk. Hope I'm not throwing you under the bus here. Quote Link to comment Share on other sites More sharing options...
Turbo Meister Posted January 26, 2005 Author Share Posted January 26, 2005 I too would really like to see the pics from before. If you have a cd burner I would send you a prepaid padded envelope and disk. Have you looked at the pics in my photo gallery on this site? If you need pics of specific parts or installed equipment I can take the pics and e-mail them to you or I can download them onto a CD as you suggested. Hanns Quote Link to comment Share on other sites More sharing options...
