stock SU carbs
Guest 72datsun240z
Guest 72datsun240z
wasup guys
I have a sort of a problem whenever i run my car and than cut it off i got fuel pourin outof the carbs specificaly the carb closer to the firewall . I had my friend thats been working with these cars his whole life look at it today and he told me the need le on the bottom of the carbs is stuck or sumthin i sure could use more opinions even though i trust my friend knows whats he talking about but i sure don't and i someone could explain it to me again than it be cool
thanks
Guest Nic-Rebel450CA
The float could be not functioning correctly, or the shutoff valve could be stuck open. Rebuild them. Costs about $30 for the pair, and can be done in a few hours if you plan it right. Heck, after doing mine, I think they can even be rebuilt while still mounted in the car!
Guest 72datsun240z
one thing i forgot to mention is that the back of the car was jacked up when that happend i let it down today and since i had to adjust the valves i ran it to see if it runs any better but crap it runs worse!!!! If it is just idling its the same but when if i rev it to 2000 rpm and than punch it it wants to day the whole engine shakes than it picks up and go high withthe rpms . It didn't ever do that before and i didn't mess with the adjustments on the carbs . Oh but one good news it didn't leak out any gasoline after i turned it off.. :roll:
please help i am at the point where i am so desperate that i wanna sell it again :x:evil:
  Quote
Just do what Nic-Rebel450CA said. Order two rebuild kits from http://www.partsamerica.com for $14.99/per. I just ordered some and they should be here on tuesday.
Phyte
Buy the rebuild kit from Ztherapy as it has an improved needle valve assembly to prevent overfilling the float chamber which may flood the carb. The stock and cheap rebuild valves can cause flooding and a fire. I also recommend buying the Ztherapy SU video.
Miles
