dskubitz Posted November 23, 2003 Share Posted November 23, 2003 After reading this forum for a while, I got bitten by the bug to upgrade my 72 240z with an 83 turbo. I bought my donor car for $200, and I am just starting to go through the engine. I noticed that the turbo has excessive play and should be rebuilt at the very least. My question is this: What would you guys recommend, rebuilding my exsisting turbo or replacing my turbo with a t3/t4 hybrid? If I do the t3/t4, what kind of mods will I be looking at? This car will be a daily driver and probably not be raced. Quote Link to comment Share on other sites More sharing options...
Guest bastaad525 Posted November 23, 2003 Share Posted November 23, 2003 I've asked this one too... most people seem to think that if you gotta rebuild that it's worth the extra $$$ to go with a better turbo. You can get T3/04 hybrids that will bolt right in like a stock replacement, with one exception that I've seen, which is that the inlet to the turbo is larger. You'll either have to adapt the rubber hose from that goes from the AFM to the turbo, to the larger diameter, or make or have a custom one made. And it may need to be reclocked, which is just re-aligning the compressor side to the turbine side, to match the alignment of the stock T3, which should be easy. The hybrid turbo will be much more efficient at moving air into your engine, and you will make more power at a given level of boost vs. the T3, but I'm not sure how this would effect the limit of how much boost you could run safely, as far as how much a stock EFI, fuel pump, injectors, etc. could support for the hybrid. Quote Link to comment Share on other sites More sharing options...
dskubitz Posted November 24, 2003 Author Share Posted November 24, 2003 Is there a place that you would recommend for a new turbo? Quote Link to comment Share on other sites More sharing options...
Lockjaw Posted November 24, 2003 Share Posted November 24, 2003 If you want one that won't break try these guys. http://www.forcedperformance.net/ Quote Link to comment Share on other sites More sharing options...
Guest Zcarsmakemyheadhurt Posted November 26, 2003 Share Posted November 26, 2003 Put a TO4B upgrade on it, the hybrid will bring up air flow at a lower boost. Use a high pressure fuel pump and a FMU to bring up fuel pressure at boost only. Don't forget to replace the headgasket on your new used engine, they are prone to failure after 13psi. Good luck and let me know it you need help with any of the parts. Quote Link to comment Share on other sites More sharing options...
Brad-ManQ45 Posted November 27, 2003 Share Posted November 27, 2003 I would get a water cooled center section and kit to install it also. Quote Link to comment Share on other sites More sharing options...
yo2001 Posted November 27, 2003 Share Posted November 27, 2003 that's what I did when I blew my stock T3, I just got a hybrid turbo because the price isn't that much different. Quote Link to comment Share on other sites More sharing options...
dskubitz Posted November 27, 2003 Author Share Posted November 27, 2003 Thanks guys for the information. I really want to do this right the first time, so I will probably get a new turbo upgrade rather than rebuilding mine. Quote Link to comment Share on other sites More sharing options...
