z31 throutel body convertion?
Guest Dr.buddha
Guest Blue02wrx
i run the z31 turbo tb on my 280 turbo. all i did was to cut the circular part out of the 280 tb and make it smooth (making it the adapter plate.) the you remove throttle blade and linkage and switch it over using the larger throttle blade from the z31. it's doable, probably not as easy as the 240 swap, but i don't have any money in mine either.
