Help With Engine/Tranny ID
Thanks Mike!
Looks like I have 305 heads. My casting # for my block do not match up with any on that site. I am thinking it may be an olds block because when i puulled the starter off I noticed it looked like the one I put in my dads olds a couple of years ago. One bolt longer than the other kinda offset. I am not happy....:cry:
Rufus
  Quote
Thanks Mike!
Rufus
Many chevy engine starters have offset bolts holding the starter. 010 at the end of your block number is a very popular chevy 350 number.
  Quote
  Quote
Block:
GM 8970010
Could you have misread the 3 as an 8 on the block?
3970010....302.....69....4...Z-28 Camaro
3970010....327.....69....2...Trucks and industrial
3970010....350...69-80...2 or 4
Hmmmm Good point I will look tonite. What are you referring to with ....4
...2? 2 or 4 bolt mains?
Rufus
On the front of the motor, passenger side, the block deck extends past the cylinder head. GM stamps this part with a block suffix code and a partial VIN number. Post these numbers for further decoding. Note, if your block has been decked, these numbers may be gone. The 3970010 can be either 2 or 4 bolt main, but all are 4" bore. It is a good block and fairly common. In the bellhousing area as well as under the timing cover will be some 2 digit numbers as well, either 10 and 10 or 10 and 20. These are in reference to the amount of tin (1%) or nickel content (1% or 2%,10 or 20) The 20 blocks are high nickel content blocks and are most desirable for wear resistance).
  • 3 years later...
Guest Cossack
Don't let anyone convince you your eyes are wrong. I have a 1967 Chevy C60 dump truck with:
Block Cast *8970010* (unidentifiable)(does not exist)
deck 10 143654 V1017CNV
Heads
*3973487*...350...71........CORVETTE...330,270 HP
*3973487*...350...71-76...PASS, CAMARO, CHEVELLE, NOVA,MONTE CARLO...SMALL PLUGS
*3973487*...350...71-76....TRUCK.......LIGHT DUTY
*3973487*...350...72........CORVETTE...200,255 HP
Intake *3877652* = 66 & 67 Intake for Passenger/Chevelle & Chevy II 283's
67 camaro 327/210 HP
1965 *3877652* 283,327 2bbl iron - A B C K,trk
Carb
7041110
110 1-CF
Year Model Trans Type/BBL OEM Number Line
1971 CAMARO 307" Eng S/T R-2-2GV 7041101 900
A/T R-2-2GV 7041110 901
CHEVELLE, EL CAMINO
307" Eng A/T R-2-2GV 7041110 913
CHEVROLET, MONTE CARLO CHEVY II
307" Eng A/T R-2-2GV 7041110 935
VENTURA II
307" Eng A/T R-2-2GV 7041110 1244
YEAR PART . C/I TRANS MAKE MODEL
1971 7041110 307 M GM TRUCK C/K/P MODELS
1971 7041110 307 A CHEVY CAMARO/CHEVELLE/EL CAMINO/NOVA
PART # YEAR BBL's C/I TRANS MAKE MODEL
7041110 1971 2 307 A CHEVY CAMARO/CHEVELLE/EL CAMINO/NOVA
So if anyone can identify a Block cast 18 GM 8970010, 10 143654 V1017CNV, Please drop me an email.
Dave
cossack@spamcop.net
