280Z strut tubes on a 240Z
Guest balcar
Ok, planning on going with the Modern Motorsport coilovers, but someone said I should go ahead and get the 280Z strut tubes for my 240Z first because they are bigger. Anyone else heard of doing this?
Thanks
Phil
Some of the more expensive racing shocks won't fit or fit very tight into a 240Z strut tube and some 280Z tubes are a bigger OD/ID so yes, I have heard of this. Not sure what year 280Z tubes you need though for the bigger ones. I measured several sets that I have lying around and they are all the same ID/OD.
I went with the 280 housings' date=' not really for the struts, but rather for the stronger companion splines.
Tim[/quote']
Tim -
Are you referring to the stub axle shafts on the rear? I did upgrade my stub axles to the 280 stubs because they're supposed to be stronger. I didn't need to upgrade the housings, though.
I put 280Z struts w/Ground Control coilovers on my 240 as well. The 280's are taller, but with the popular shortening (front cartriges in the back) it doesn't matter. After sectioning them, I just went off of the 240 perch specs and it came out perfect. I beleive the rear strut towers are actually taller on the 280's as well.
