Guest balcar Posted December 2, 2003 Share Posted December 2, 2003 Ok, planning on going with the Modern Motorsport coilovers, but someone said I should go ahead and get the 280Z strut tubes for my 240Z first because they are bigger. Anyone else heard of doing this? Thanks Phil Quote Link to comment Share on other sites More sharing options...
gramercyjam Posted December 2, 2003 Share Posted December 2, 2003 Some of the more expensive racing shocks won't fit or fit very tight into a 240Z strut tube and some 280Z tubes are a bigger OD/ID so yes, I have heard of this. Not sure what year 280Z tubes you need though for the bigger ones. I measured several sets that I have lying around and they are all the same ID/OD. Quote Link to comment Share on other sites More sharing options...
Wagz Posted December 2, 2003 Share Posted December 2, 2003 I'm not sure what you would be gaining by going to the 280 strut housings, but for what it's worth, I just sectioned my 240 housings and installed coil-over kits on all 4 corners of my 240Z and no problem with fittment. Quote Link to comment Share on other sites More sharing options...
Tim240z Posted December 2, 2003 Share Posted December 2, 2003 I went with the 280 housings, not really for the struts, but rather for the stronger companion splines. Tim Quote Link to comment Share on other sites More sharing options...
Wagz Posted December 2, 2003 Share Posted December 2, 2003 I went with the 280 housings' date=' not really for the struts, but rather for the stronger companion splines.Tim[/quote'] Tim - Are you referring to the stub axle shafts on the rear? I did upgrade my stub axles to the 280 stubs because they're supposed to be stronger. I didn't need to upgrade the housings, though. Quote Link to comment Share on other sites More sharing options...
Tim240z Posted December 2, 2003 Share Posted December 2, 2003 I just grabbed the entire housing and bolted it in. Tim Quote Link to comment Share on other sites More sharing options...
A. G. Olphart Posted December 3, 2003 Share Posted December 3, 2003 Tim, did you have any trouble with length? (Someone said 280 rear struts were longer than 240's... besides the taller mounting insulator). Is the spring perch the same distance from the axle? Inquiring minds, and all that. Quote Link to comment Share on other sites More sharing options...
Tim240z Posted December 3, 2003 Share Posted December 3, 2003 Hmmmm...I'll have to go out and measure. I'm running coilovers, so ride height is adjustable. The top isolators are taller for sure. Tim Quote Link to comment Share on other sites More sharing options...
mike240zt Posted December 4, 2003 Share Posted December 4, 2003 280 strut tubes are larger in diameter and height. Quote Link to comment Share on other sites More sharing options...
preith Posted December 5, 2003 Share Posted December 5, 2003 I put 280Z struts w/Ground Control coilovers on my 240 as well. The 280's are taller, but with the popular shortening (front cartriges in the back) it doesn't matter. After sectioning them, I just went off of the 240 perch specs and it came out perfect. I beleive the rear strut towers are actually taller on the 280's as well. Quote Link to comment Share on other sites More sharing options...
