Sick! Dyno tuned my car
Guest Simon
Just dyno tuned my car... It is running very well and oh so smooth!!
The VG30DET and Wolf3D computer are a good combo!!
224.4HP at the wheels and 850lbs of TQ at 6.0 PSI
TQ peaks at 2800 RPM at 850 Lb then drops to about 810 Lb at 5200 RPM then drops quite abit after that
is Lb = same as lbs ? thats what i assumed
being ft/Lb the graph reads 850Lb
torque x rpms divided by 5252 gives you hp right?
so 100 ft.lbs at 5000 rpm = 95hp sound right!
850 at 2800rpm = 453hp
810 at 5200rpm = 802hp
don't want to be negative, but.
lets go the other way.
hp x 5252 divided by rpm = torque
so 224hp x 5252 = 1176448 divided by 5200 rpm = 226 ft.lbs
hp sound right, torque has to be wrong.
Guest Nic-Rebel450CA
Zsane's math looks right to me.
(Unless you have an 80% drivetrain loss :P )
Maybe that dyno graph is just an example of bad graphing. I have seen dyno sheets where they put both graphs on the same sheet and the numbers get confused because one graph is bumped up on the page and then you end up reading outrageous numbers that are for if the bottom graph came up that high on the page.
Zsane i think you re on it there
the car does have 850 pounds of TQ but the distance is what i dont know about ... there not foot pounds ft/lbs its some other distance x/lbs i will find out on monday
thanks for your help
yo2001 it only spikes to about 10 PSI then quickly down to 6 PSI... I wouldnt have though it was that big... Ive seen people with spikes of 8-10 PSI mine in only 4 PSI
here is the Dyno Graph, just a picture i took with my phone... i will scan it when i get the chance...
pretty flat tq curve
yo2001 I use a MAP sensor and aftermarket computer... not the MAF... so if the pressure is to spike the computer will still dump in the correct amount of fuel into the engine... so for me spikes just mean MORE POWER
I will be running more boost after i get an intercooler in there.... the VG30DET is unintercooled standard... but that will be comming!! I want to run about 12 PSI, also i think the standard turbo will only hold up to that...
Cash is short... just had to buy a beefier clutch and pressure plate
Aslo my diff isnt in the best shape.... few sounds that are not quite right
Stony: the timing is just so they can get the RPM of the engine
if they use the RPM of the wheels depending on what gear you are in you will get HUGE torque figures like mine...
here is the Dyno Graph' date=' just a picture i took with my phone... [/quote']
Umm.. if that is even the torque curve, just because you read it against the numbers on the right does not make that the value.. There is no where on that graph that the torque value is written. There is no scale on the graph to go along with the torque line.
You do not have 850 ft/lbs of torque. If you did, you would have 453HP (which you do not).
