Nismo280zEd Posted December 9, 2003 Share Posted December 9, 2003 ok... so i convience O'Reilly's to order me two motors in for free just to look at. Ordered an 80 280zx and a 94 honda accord sedan EX. the 80 model will pretty much bolt right up. The 94 honday motor is smaller than the 80, and is VERY easily adaptable. All i would have to do is take a dremel or a grinder to it and make the rectangular notch that mounts to the wiper bars. very easy. I know how fast the honda wiper blades are as i drive one currently, But how fast is the ZX wipers? same speed as the 78 280z? or faster? the difference in price is about 40 bucks.... the zx is 80 the honda is 121. Let me know what ya think gonna pick one up sat after friday's paycheck. -Ed Quote Link to comment Share on other sites More sharing options...
zcarnut Posted December 10, 2003 Share Posted December 10, 2003 Don't forget that most of the later model wiper motors require a separate control box that interfaces with the wiper motor and the column switch. Although the ZX and Honda wiper motor may "bolt in", I doubt that your existing Z wiring harness and column switch will "plug in" the corresponding control box. Prepare to do some re-wiring and hope you can get your column switch to activate the later wiper motor. Otherwise, you may have to change this as well and then you might as well use junkyard parts for everything. Quote Link to comment Share on other sites More sharing options...
jeromio Posted December 10, 2003 Share Posted December 10, 2003 I disagree. The wiper motor does not require the control box. That is there to perform the interval wiper functionality. I'm curious about this - although I'm too cheap to pay $80 for a new motor, I wouldn't mind picking up the ZX motor from a yard. Quote Link to comment Share on other sites More sharing options...
Nismo280zEd Posted December 11, 2003 Author Share Posted December 11, 2003 Well i'm really leaning toward the honda motor as i live in houston, TX and it rains quite i bit here... also Flroida is in my future and it likes to rain there as well. So far, i've re-wired ignition, headlights, radios, altenators, converted fusible links, wired in relays to take more load, new fuseblocks, etc. I think matching up prong for wire from the motor shouldn't be too dificult. Pluse i've got the repair manual for the honda so it should ahve the wiring for it in there... and if that doesn't work.. i have the car to go look and see how honda wired it. Plus... the honda and the Z have the same amount of switch speeds, Int, Medium, Fast. and the both have the feature to push where it sprays fluid and wipes. So i think it should go pretty smooth. If all works our i'll write up a post and put some pics on here for future Z guys.. i know many would be interested. -Ed Quote Link to comment Share on other sites More sharing options...
CruxGNZ Posted December 11, 2003 Share Posted December 11, 2003 Ed, Please keep us updated on this. Very interesting! !M! Quote Link to comment Share on other sites More sharing options...
Guest kirbwah Posted December 11, 2004 Share Posted December 11, 2004 what ever eventuated from this? ps sorry to revive. Quote Link to comment Share on other sites More sharing options...
Metro Posted December 12, 2004 Share Posted December 12, 2004 what ever eventuated from this? ps sorry to revive. Look at the sticky in the high tech forum Quote Link to comment Share on other sites More sharing options...
TomoHawk Posted May 5, 2005 Share Posted May 5, 2005 Are there any good wiring diagrams for this motor swap? I haven't been able to get my wiper relay out, until I get the engine runniong so I can get out of storage. thx Quote Link to comment Share on other sites More sharing options...
DaleMX Posted May 5, 2005 Share Posted May 5, 2005 Brandonz emailed me this. Hope it helps. http://www.zcar.com/forums/read.php?f=1&i=570239&t=570239 Quote Link to comment Share on other sites More sharing options...
TomoHawk Posted May 5, 2005 Share Posted May 5, 2005 I saw that. It gives you a lot of info, but no wiring diagram. I'd like to see the big picture, not pinouts. Maybe if I have time, I can printout the pages, and try to draw something. trhx Quote Link to comment Share on other sites More sharing options...
DaleMX Posted May 5, 2005 Share Posted May 5, 2005 Yea it does, about halfway down it shows how he wired it. If you want a diagram back to the wiper controler then buy the service manual. I know the PDF one I got from Nissan has the diagram. Quote Link to comment Share on other sites More sharing options...
TomoHawk Posted August 24, 2005 Share Posted August 24, 2005 Can you measure the distance between the bolts on the motor? I assume there are three holes equally spaced. I can check out various cars at the JY or my Escort, to see if there is another that will fit the bolt patern. Maybe a domestic model will be easier or cheaper. thx Quote Link to comment Share on other sites More sharing options...
TomoHawk Posted October 14, 2015 Share Posted October 14, 2015 (edited) It turned out that the Ford Escort wiper motor is just about the same size and bolt pattern, and even has it's own auto-park! But the wiring would need to be figured out. It has a ground, and one wire for low speed, and one wire for high speed. Edited October 14, 2015 by TomoHawk Quote Link to comment Share on other sites More sharing options...
