Z_Dust Posted December 11, 2003 Share Posted December 11, 2003 The valves on my N47 are noisy to the point that people keep telling me, "Hey man you need to adjust your valves...". I'm kind of tired of listening to the tapping and the people over and over. Problem is I can't find the book (imagine that) with the valve specs. Can someone tell me what to adjust them to, cold & hot, I/E Thanks to all Quote Link to comment Share on other sites More sharing options...
Guest Nic-Rebel450CA Posted December 11, 2003 Share Posted December 11, 2003 I dont know by the "N47" badge, but if you tell me the year and model I can look it up in my Chilton manual. Quote Link to comment Share on other sites More sharing options...
johnc Posted December 11, 2003 Share Posted December 11, 2003 Hot clearance Intake .010" or .25mm Exhaust .012" or .30mm Cold clearance Intake .008" or .20mm Exhaust .010" or .25mm I adjust when the engine is cold and then check again when its hot. Quote Link to comment Share on other sites More sharing options...
Z_Dust Posted December 11, 2003 Author Share Posted December 11, 2003 Cool!! Thanks for the prompt reply guys, now back to work. Quote Link to comment Share on other sites More sharing options...
Guest shane280z Posted February 6, 2004 Share Posted February 6, 2004 Kammy at Zcar.com has an excellent pictorial on how to adjust yor valves for newbies. Go to the 70-83 Tech Section. Go to Search. Type Kammy and click Author only and past 60 days. Quote Link to comment Share on other sites More sharing options...
Nismo280zEd Posted February 11, 2004 Share Posted February 11, 2004 after you do your vavles, check compression. They sould be around 165 with a 280z. If it isn't that high, just make sure they are all within 5lbs of each other. Quote Link to comment Share on other sites More sharing options...
