240Z Turbo Posted January 2, 2004 Share Posted January 2, 2004 Hoovers car has a billet bottom end and 8.5-1 or so cr, motec, custom everything, and the almightly garret gt2530 or maybe even bigger by now. FYI, a GT2530 is very small. It is a GT25 turbo that flows 30lb/min or about 325hp max. Those are HKS designations for the GT stuff. Check out this link on the GT stuff. http://www.turbofast.com.au/GTseries.html Quote Link to comment Share on other sites More sharing options...
Guest exahertz Posted January 5, 2004 Share Posted January 5, 2004 An '83 280zx already comes with an L28E correct? so an L28et should be an easy swap right? Would I just need a longblock and an IC or would a motorset be needed. Everything should drop right in, but I figure an exhaust upgrade would be wise. How much would this swap cost (with intercooler and piping)? where can I find this engine. Thanks, Matt Quote Link to comment Share on other sites More sharing options...
Guest Boyd Posted January 5, 2004 Share Posted January 5, 2004 Click http://bellsouthpwp.net/b/o/boyd3852/MVC-315F.JPG for a pic of the 2.5" mandrel bent IC piping and large Spearco I mounted in my '77. The car ain't pretty, which makes it even more fun when I rip away from a redlight like somebody stole it. Quote Link to comment Share on other sites More sharing options...
SleeperZ Posted January 5, 2004 Share Posted January 5, 2004 An '83 280zx already comes with an L28E correct? so an L28et should be an easy swap right? Would I just need a longblock and an IC or would a motorset be needed. Everything should drop right in' date=' but I figure an exhaust upgrade would be wise. How much would this swap cost (with intercooler and piping)? where can I find this engine. Thanks, Matt[/quote'] The exhaust is different (it dumps in a different place) , the fuel pump is different, the AFM is different, and the ECU/wiring harness is different. Swap all that, with a complete[/b engine (injectors, distributor, intake, turbo, oil pan and oil lines), you should be good to go. It's helpful to have an entire turbo car to part out. Quote Link to comment Share on other sites More sharing options...
Guest exahertz Posted January 5, 2004 Share Posted January 5, 2004 I believe a clip should solve the wiring harness, ecu, and AFM problems. Won't the fuel pump and intercooler w/ piping be there too? I would probably look for an old 280zx turbo exhaust to solve that problem. Are you running on stock internals @ 16psi and what is the L28et dyno at stock? Thats a hell of a track time for Denver. Seems like a turbo is almost a must there to make up for the lack of oxygen. What did your swap end up costing you and where can I find a turbo clip? Quote Link to comment Share on other sites More sharing options...
SleeperZ Posted January 6, 2004 Share Posted January 6, 2004 I believe a clip should solve the wiring harness' date=' ecu, and AFM problems. Won't the fuel pump and intercooler w/ piping be there too? I would probably look for an old 280zx turbo exhaust to solve that problem. Are you running on stock internals @ 16psi and what is the L28et dyno at stock? Thats a hell of a track time for Denver. Seems like a turbo is almost a must there to make up for the lack of oxygen. What did your swap end up costing you and where can I find a turbo clip?[/quote'] You seem to be thinking in terms of a Japan import if you are talking "clip". I bought a donor, running but bent, for $750. I've not heard of folks sourcing Jspec S130s - probably because it's gonna cost a lot more. The S130 turbos never had intercoolers, that's custom. The fuel pump should be upgraded first anyway, the factory pump isn't very good. Don't know what a stock S130 turbo puts down, probably about 150rwhp. Yes, I'm running a bone stock engine, with an upgraded turbo, fuel system, exhaust and intercooler. And yes , turbo rules up here in the clouds - V8s don't know what hit them. And I can't really say what the whole deal cost me, I've had the car 12 years, turbo'd 6 of those years. Just to run the time, I'd say I've spent $5000. Quote Link to comment Share on other sites More sharing options...
Guest Rusty260z Posted January 22, 2004 Share Posted January 22, 2004 So obtaining 250-300rwhp reliably wouldn't be that hard to attain?? I'm restoring my 260 to make it a daily driver....would like the L28et and it do a lil more than stock....but will only have around 2-2.5k to spend on the engine. Thats with everything else complete though....brakes, rearend, suspension, body, interior..etc. So after all is said and done I should have the 2.5k to throw on the engine...and right now thats the one thing I can't decide on....will I be able to do the L28et...or should I look at just carbing and building a L28 maybe w/ some spray. I know for my money it can be done...but what level of reliability and around what kind of power am I looking at? Thanks for any help. Quote Link to comment Share on other sites More sharing options...
