fl327 Posted January 3, 2004 Share Posted January 3, 2004 Wondering if anyone runs one of these, they make an adapter/spacer deal that I am looking into using in order to finally use the t04e on my car, and I want to use my tial wastegate since I already have it. Im wondering if anyone uses one or knows if the flanges are compatible. Yeah, last years last race has me going for the big guns Quote Link to comment Share on other sites More sharing options...
240zprace Posted January 3, 2004 Share Posted January 3, 2004 i believe with that spacer the turbo will stick out about an inch and a new downpiping has to be made. Quote Link to comment Share on other sites More sharing options...
fl327 Posted January 3, 2004 Author Share Posted January 3, 2004 I have to make a downpipe anyway, the T04e has a 3" Vband flange on the end, not a four bolt flange. OH man, open wastegate dump with a motorcycle muffler sticking out behind the front wheel, oh boy!!! Anyone know if wg flanges match? Quote Link to comment Share on other sites More sharing options...
SleeperZ Posted January 3, 2004 Share Posted January 3, 2004 Got a link? Quote Link to comment Share on other sites More sharing options...
fl327 Posted January 3, 2004 Author Share Posted January 3, 2004 http://innovativeturbo.com/cgi-bin/htmlos.cgi/00196.1.635694651863228247 I think its here, its definitely on their site though, they have some cool stuff. Now that I look at it I think it will work, since they probably make their wastegates to go where a tial or turbonetics used to be. Quote Link to comment Share on other sites More sharing options...
SleeperZ Posted January 3, 2004 Share Posted January 3, 2004 Thanks, that's looks like a useful piece for those of us who are welding impaired (me). I assume that's a standard T3 adapter? Have you priced it yet? Maybe it would fit the Audi wastegate... Quote Link to comment Share on other sites More sharing options...
fl327 Posted January 3, 2004 Author Share Posted January 3, 2004 Yeah, its a slick piece and hopefully it solves a few things for me. The only guy I know that tigs doesnt trust himself with cast iron and im scared of crappy work on something like this, so that piece will do the job hopefully. Overboost.com sells it for 112.00, I think thats very reasonable! Im going to call them later this week and ask them for a t3 on one side and t4 flange on the other, shouldnt be much more hopefully. Ive been doing my research on setting up the t4 and so far its been the best looking prospect yet. I think its a t3 flange standard. Quote Link to comment Share on other sites More sharing options...
Kennysgreen280zt Posted January 4, 2004 Share Posted January 4, 2004 Thanks, that's looks like a useful piece for those of us who are welding impaired (me). I assume that's a standard T3 adapter? Have you priced it yet? Maybe it would fit the Audi wastegate... that looks like the normal tial/turbonetics wastegate mount. I dont think any audi wastegate uses that pattern, I have an audi gate in the garage and it uses an odd shaped 4 bolt pattern. Im sure every audi up untill 96-97 used the same wastegate too. HTH ~Kenny Quote Link to comment Share on other sites More sharing options...
Vintage-TechZ Posted January 31, 2004 Share Posted January 31, 2004 Hey FL27, I still havent had luck posting pix here so I'll e-mail it to you,but it's of the T4/E downpipe adapter I turned on a lathe in order to make use of the v-band clamp in a real smooth 45 degree stainless exit.It actually slips into the I.D. and has a zero interior transition as it mates up. Maybe I'm dreaming ,but I could swear it changed the sound,spool response and back pressure for the better ! I won't lie,it took about 9 hours to prototype it on the lathe but it fits perfectly and lools so proper not to mention how easy it makes everything to install/uninstall.Let me know what you think I'll try to get more angles to you if you like ? Vince Quote Link to comment Share on other sites More sharing options...
Twentyfourouncer Posted February 17, 2004 Share Posted February 17, 2004 So did anyone ever purchase this flange? And did it work out? I'm also interested in this piece but I am wondering if there are clearance issues? Quote Link to comment Share on other sites More sharing options...
Guest Chris240turbo Posted February 26, 2004 Share Posted February 26, 2004 I replyed to this before the site went down, here's the new abridged version: I ordered this adapter a couple days ago, it's a full T-4 flange only, and all they had left was the "slim" 45 degree adapter, it SHOULD work with my new on center T-4 turbine, which will raise the turbo on the manifold some, but they are still considering casting more of the 90 degree models, which would likely be a better fit,and it only comes with a flange to fit either a turbonetics 42mm racegate or innovative's 42mm progate ($$$$$) I bought a racegate, I'll take pictures as soon as I get the parts. Chris Quote Link to comment Share on other sites More sharing options...
fl327 Posted February 29, 2004 Author Share Posted February 29, 2004 Didnt go with that setup, although I do like it. Had a t3 to t4 adapter drilled the t3 side straight thru and countersunk the holes, got shorter studs and it bolts on. Adapter acts as a spacer. 2" maybe smaller pipe L shape welded in between 5 and 6, needs more welding. Should be fun soon... Quote Link to comment Share on other sites More sharing options...
