Show me your slips
Guest 6.6l_zcar
Guest 6.6l_zcar
If any of you boys are running SBC in a "stock" z. and have taken it to the track, Let me know what you run. ie 1/4 mile, 60', 1/8 mile. and then a brief overview of your setup, HP, trans. Modified suspention need not apply(9in rear end)
Mine's a 305TPI w/ 700r4. Crane 2-5k cam, L98 heads, block huggers, cut-outs. Runs in the 12.80's @ ~104 w/ 3.73 R200 rear. 8.20's in the 1/8th, 1.8's 60ft. these are when she's hooking. 13.20's, 8.50's, 2.1's when she ain't. Just upgraded to 8.8 solid rear. i drove it up and down my street 1 time but haven't made a run at the track yet. Runnin' 3.27 gear now.
i liked the squat and leave of the IRS, but the 8.8 should allow me to wail on it with slicks without crossing my fingers every time. But this means i'll prolly bust the tranny soon :roll:
I have a 1971 240Z with a 383 sbc /700r4 auto trans built up. Stall is 2600 rpm's. I am running a lsd 3.70 out of a 1987 300zxt.
The car with 235/60-15 drag radials has run 11.62 at 119 mph with a 1.76 60 ft. and 7.40 for the 1/8th mile.
Mike
Guest stpdfst_in_TN
zfan,
Do you know how much your car weights and your approx HP? What rear gear are you running? I'm currently building my '78 280 with a 383. Your times look awesome and you still have the independant rear suspension. Congrats!
So does an LS1 count as an SBC?
LS1/T56; 3.70:1 R200 LSD in '77 280Z. 225/50-16 street radials, car weighed 3,085 with me in it. 12.95@110mph; 2.05 60' & 8.86 1/8th. CAr chassis dyno'd at 311 RWHP & 326 RWTQ. At least it's a comparison with a manual vs. automatic and heavier 280Z vs. 240Z.
71 240Z 2850lbs with driver.It runs 10.80 on the motor and 10.20 with a 125 horse shot of nos on pump gas in street trim.My 60 foots are 1.46-1.52.
406 with airflowresearch 190 heads
400 turbo with 3200 stall
et streets
Hooker headers 3inch pipes and flowmasters
R 200 3.70
John C
My car weighs 2760 with me in it. The rear gears are 3.70's out of a 1987 300zxt. I have no idea what horsepower it makes as I had just dropped the motor in the car with less than 100 miles when I ran it at the track.
With some tuning it is noticably faster I think now, maybe low 11's, who knows? I guess it is probably 350 to 375 to the rear wheels.
Mike
John C: ET Streets are not street trim :x:wink:
350 TPI, chevy cast iron Phase II heads, 230/236/110 510/520 lift, fully ported stock plenum/base w/ fully siamesed SLP runners, T56 tranny, stock R200 3.53, Road Hugger 225/50/16 tires.
12.74@109.75
355, TH350, 4.11 r200 about 9.5:1 trw flattops, mildported darts sportsmanII`s, team g intake, 750dp,shortys, small solid roller cam 235/@.50 and 550 lift, 2650lbs without me in it, slicks, 2 1/4 duel to a 2 1/2 single, no muff& air cleaner at track, i lost my 11.68 time slip :( here is a most recent one last nov, track was in bad shape
60'.....1.809
1/8.....7.649
1/4.....11.90@114.79
73 240z
400 sb std bore, stock #882 heads, flattop pistons,LT1 cam (.460 lift) w 1.6 rockers,830 holley db, victor jr intake,stock HEI, turbo350 w loose 12"convert (2200stall), r200 3.90 w280zxt shafts, 2 1/2 y into single 2 1/2 into 1 flowmaster 3" muffler w/3" Electric cutout.
best 1/4 12.2 @111 on drag radials...leaning out on topend
this year easy 11`s if I remember to bring the jets this time!!!!
Mark
I knew someone would say that! :) They are street trim to me at 18 lbs,and I don't race around turns.I buy a new set every spring and sell them in the winter.I've done this 4 years now,and drive 20 minutes each way to work.
1971 240Z lowered 1 inch
15" centerlines (8's in back and 6's up front)
Heavy springs in the rear with raised spring perches
No sway bar
honda crx seats
no roll bar
white auto meter gauges
2600 lbs empty
362 sbc (3.550" stroke and 4.030" bore)
11.3:1 cr (flat tops, zero deck block)
iron eagle heads (64cc combustion chambers, 200 cc intake runners)
cast crank with 4 bolt mains
292H comp cam
performer rpm intake
holley 750 3310 carb
150 shot N20 (I use a 1 gallon fuel cell in front of car with racing fuel for N20 fuel enrichment)
GM T5 trans
3.90 r200 diff
brake linelock
MT slicks (26x8.5x15)
sintered iron clutch
full lenght headers with 1 5/8 tube, 2.5 inch exhaust, two 2.5 hooker areochambers.
10 gallon fuel cell and mallory 140 pump
10.7 sec at 134 mph, 1.5 sec 60 footers, 6.9 at 110 in the 1/8 mile.
I finish the 1/4 mile at the very top of 4th gear.
The car drives well on the street and doesn't over heat. (Black magic fan with GM radiator)
My times are slow compared to the mph because I shift slow to save the trans. I plan to go automatic, turbo, and a straight axle because I'm sick of breaking parts. I can't race the car anymore until I install a roll cage!
Guest Fastest240z
Mine run's 10.3 @ 131 on the motor with 1.48 60' times. On the nitrous the car has gone as quick as 9.10 @ 149 with 1.23 60' time. When I use the nitrous I leave on the button right out of the hole with my foot to the floor. I don't have any traction problems, but I have had to deal with heart stopping wheelies. After restricting the front end travel to zero, I don't have as much of a problem anymore.
Mark
Mine run's 10.3 @ 131 on the motor with 1.48 60' times. On the nitrous the car has gone as quick as 9.10 @ 149 with 1.23 60' time. When I use the nitrous I leave on the button right out of the hole with my foot to the floor. I don't have any traction problems' date=' but I have had to deal with heart stopping wheelies. After restricting the front end travel to zero, I don't have as much of a problem anymore.
Mark[/quote']
Mark,
Great car!! I saw your 9.25 run at the True Street drags on ESPN. You were the fastest street car there and successfully completed a 30 mile drive prior to the drag race. That wheelstand was awesome when you launched.
Is your front suspension beefed up to handle the impact after you come down from the wheelstand?
You must have a 4 link rear suspension that is heavily modified to handle those launches.
Welcome to Hybridz.
Hanns
