240zprace Posted January 27, 2004 Share Posted January 27, 2004 72 240zt, is there a relay of some sort going to the brake light. the left one works fine, but the right one dosen't. i'm talking about the bulb that has two filaments inside..(brake and turn signal one). the turn signal works fine, but when brake applied, it dosen't light up. the other side is ok. apparently the is no current to the side that dosent work, but when turn sig is on there is current. plese help troubleshoot...... Quote Link to comment Share on other sites More sharing options...
gramercyjam Posted January 27, 2004 Share Posted January 27, 2004 I'd look at the combination switch on the steering column. Maybe a wire fell off you can solder back on. Quote Link to comment Share on other sites More sharing options...
BillZ260 Posted January 28, 2004 Share Posted January 28, 2004 Check the GROUND! All those lights are on a common ground wire in that nasty harness. Quote Link to comment Share on other sites More sharing options...
